[snappyHexMesh] Snappy : Multi-region meshing
Like Tree4Likes
Old   March 28, 2012, 08:12
Daniele Vicario
danvica is on a distinguished road
@aurelien
That's all ? So simple ? I thought the common surfaces between two regions need to be meshed exactly the same way (same points)... actually I thought they were the same mesh named in two different ways.
@antonessiu
I think you can try lower your refinement level requirement.
In the sHMDict I posted yesterday the setup is quite coarse...
Daniele
danvica is offline   Reply With Quote
Old   March 28, 2012, 08:30
Aurelien Thinat
Aurelien Thinat is on a distinguished road
In "wonderfull land", you should use only structured mesh (the exact same surface mesh for both fluid region and solid region) to get the best results.
But in real life since I was not able to deal with SHM, an unstructured mesh is a first solution. If you use the same cell size for both regions, you will be able to limit the error from the meshes differences.
I have already checked OpenFOAM can deal with it on a simple test case. With SHM, The only problem that could appear is from the feature edge option. Sometimes SHM is a bit crafty. But with an other mesh tool, it would be easy.
Aurelien Thinat is offline   Reply With Quote
How I can introduce my power heat (W) in chtMultiRegionFoam? aminem OpenFOAM Pre-Processing 32 August 29, 2019 03:23
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
[snappyHexMesh] New multi region meshing tutorial with sHM Tobi OpenFOAM Meshing & Mesh Conversion 0 November 24, 2014 18:42
[snappyHexMesh] Snappy. Mesh region between 2 concentric stls be_inspired OpenFOAM Meshing & Mesh Conversion 3 May 20, 2014 14:21
[snappyHexMesh] How to generate geometry - multi region stl, obj wersoe OpenFOAM Meshing & Mesh Conversion 0 June 1, 2013 04:02
