[Commercial meshers] OpenFOAM cannot read the mesh .neu (GAMBIT mesh file)
Like Tree3Likes
Old   August 6, 2013, 08:24
Default conversion of fluent mesh into OF
  #21
sonu
yash.aesi is on a distinguished road
helo ,
can anybody tell me how to convert my .mesh file in OF ? i know the command but can anybody tell me in detail ... what i have to do in fluent to make it ASCII ?
yash.aesi is offline   Reply With Quote
Old   August 7, 2013, 03:22
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
export your mesh file .msh from Gambit (you don't have to do anything with Fluent)
Then in OF, just use the command fluentMeshToFoam or fluent3DMeshToFoam
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   August 7, 2013, 08:57
sonu
helo max ,
i tried to follow above said but while executing the conversion following error is coming .....Create time
fileName::stripInvalid() called for invalid fileName UntitledFolder
For debug level (= 2) > 1 this is considered fatal
Aborted (core dumped)
and i tried it with changing the mesh file name also but its not working ....
Old   August 7, 2013, 09:06
-mAx-'s Avatar
Maxime Perelli
paste exatly what command you gave, and where you executed it
Old   August 7, 2013, 09:12
sonu
gambitToFoam /OpenFOAM/yash-2.2.0/run/tutorials/cavity/yash.neu
this is the command i used after making new case file with the name cavity and copying 0 , constant and system file in it . also my .neu file ....
Old   August 7, 2013, 09:21
sonu
i also tried with this command ...........
fluentMeshToFoam /OpenFOAM/yash-2.2.0/run/tutorials/cavity/yash.msh
Old   August 7, 2013, 10:05
-mAx-'s Avatar
Maxime Perelli
where are you executing this command?
use pwd command for knowing where you are
>pwd
Old   August 8, 2013, 05:49
sonu
helo max
thanks alot for your help . mesh conversion is done and at the end it also saying mesh ok . now i have one doubt in my mind that now should i need to make change in the constant /polymesh file regarding geometry or it is already done while conversion ??
Old   August 12, 2013, 01:42
-mAx-'s Avatar
Maxime Perelli
It is already done.
Old   August 12, 2013, 02:44
Smile
  #30
sonu
helo ,
thanks max .
Custom Thermophysical Properties wsmith02 OpenFOAM 4 June 1, 2023 15:30
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 19:13
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 18:34
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 07:42
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
