[snappyHexMesh] snappyHexMesh
Old   September 30, 2011, 07:05
Default snappyHexMesh
supercommandodhruv
dhruv is on a distinguished road
I am using OF 2.0 and sHM. I have a rectangular channel with some internal thickness. I want to have boundary layers on the inside walls of this channel. When I do the meshing with snappy using the featureEdge, the boundary layers are not extended through the entire length of the channel, especially near the corners of the geometry. I am attaching pictures of the generated Mesh. Can anyone tell me how to make a consistent layer? I am also attaching the sHMDict file.
*--------------------------------*- C++ -*----------------------------------*\
| \\ / F ield | OpenFOAM Extend Project: Open Source CFD |
| \\ / O peration | Version: 1.6-ext |
| \\ / A nd | Web: www.extend-project.de |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object snappyHexMeshDict;
castellatedMesh true;
snap true;
addLayers true;
geometry
geo.stl
type triSurfaceMesh;
name geo;
refBox
type searchableBox;
min (-20 0 -20);
max (855 850 850);
castellatedMeshControls
maxLocalCells 5000000;
maxGlobalCells 10000000;
minRefinementCells 5;
//maxLoadUnbalance 0.10;
nCellsBetweenLevels 3;
features
file "geo.eMesh";
level 2;
refinementRegions
refBox
mode inside;
levels ((0.1 1));
refinementSurfaces
geo
level (1 2);
resolveFeatureAngle 150;
locationInMesh (50 50 50);
allowFreeStandingZoneFaces true;
snapControls
nSmoothPatch 5;
tolerance 4.0;
nSolveIter 30;
nRelaxIter 5;
nFeatureSnapIter 10;
addLayersControls
layers
"geo_walls"
nSurfaceLayers 10;
relativeSizes true;
expansionRatio 1.05;
finalLayerThickness 0.1;
minThickness 0.1;
nGrow 1;
featureAngle 150;
nRelaxIter 5;
nSmoothSurfaceNormals 1;
nSmoothNormals 3;
nSmoothThickness 10;
maxFaceThicknessRatio 0.5;
maxThicknessToMedialRatio 0.3;
minMedianAxisAngle 130;
nBufferCellsNoExtrude 0;
nLayerIter 50;
nRelaxedIter 20;
meshQualityControls
maxNonOrtho 65;
maxBoundarySkewness 20;
maxInternalSkewness 4;
maxConcave 80;
minFlatness 0.5;
minVol 1e-13;
minTetQuality 1e-30;
minArea -1;
minTwist 0.05;
minDeterminant 0.001;
minFaceWeight 0.05;
minVolRatio 0.01;
minTriangleTwist -1;
nSmoothScale 4;
errorReduction 0.75;
relaxed
debug 0;
mergeTolerance 1e-6;
dhruv is offline   Reply With Quote
Old   October 1, 2011, 17:02
Retired Super Moderator
Bruno Santos
Greetings dhruv,
Try checking first the resolution after only running the castellatedMesh phase. Either put the other two to false or run snappyHexMesh without "-overwrite".
Then check the level of resolution in that area that is missing the very refined zone. That kind of stopping the layer before reaching the corner, is usually due to some parameter (that I don't know about); but basically, it stops 1 cell before the corner. By looking at the attached images, there is additional refinement after the snapping, which enhances the resolution near the corners, but still has that previous limitation.
Either way, try the isolate-and-conquer process
Best regards,
Bruno
Old   October 5, 2011, 04:47
supercommandodhruv
Hi Bruno,
Thanks for the reply. Do you mean that I should run each step separately without overwriting the constant/polyMesh dir? Will it make a difference to the final Mesh?
Dhruv
Originally Posted by wyldckat View Post
Greetings dhruv,
Best regards,
Bruno
Old   October 5, 2011, 10:27
Bruno Santos
Hi dhruv,
The idea is to have access to the intermediate meshes, in order to figure out in which stage things get broken. The meshes for each stage will be saved in a time snapshot/instance.
It might make a difference, but AFAIK the main difference would only be that some cells wouldn't get removed.
Good luck!
Bruno
[CAD formats] Creating waterproof STL using snappyHexMesh or salome Tobi OpenFOAM Meshing & Mesh Conversion 58 May 13, 2020 07:01
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing peterhess OpenFOAM Meshing & Mesh Conversion 2 January 3, 2018 03:54
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. jasv OpenFOAM Meshing & Mesh Conversion 4 May 10, 2016 03:55
[snappyHexMesh] snappyhexmesh doesn't creat mesh in parallel issue? klausb OpenFOAM Meshing & Mesh Conversion 1 March 7, 2015 12:55
[snappyHexMesh] stitchMesh and snappyHexMesh gdbaldw OpenFOAM Meshing & Mesh Conversion 0 December 23, 2009 03:09
