[snappyHexMesh] Combine snappyHexMesh with existing mesh
Old   September 30, 2011, 01:00
Default Combine snappyHexMesh with existing mesh
Saxwax
Saxwax is on a distinguished road
Hello All,
I was wondering if there is anyway to use snappyHexMesh (sHM) in conjunction with an existing mesh?
I have a structured multi-block mesh that I created in Pointwise. At present the mesh only extends slightly beyond the boundary layer. The complexity of the geometry I am working with makes it difficult to "fill" the remainder of the domain with blocks. Also the range of flow orientations required means that I would need to re-mesh several times to keep the cells more or less aligned with the flow. I also need to think about the wake refinement for each of the flow orientations. There is the option of using tetrahedral cells to "fill" the remainder of the domain. I just had the idea that there might be a way to use sHM instead - especially now that there is feature handling in 2.0.*.
Has anyone tried anything like this before?
Regards,
D.
Saxwax is offline   Reply With Quote
Old   September 30, 2011, 03:56
Elvis
elvis will become famous soon enough
=>There is the option of using tetrahedral cells to "fill" the remainder of the domain.
For me it looks like that polyDualMesh is the right tool for you
polyDualMesh: Creates the dual of a polyMesh, e.g. can be used to generate a “honeycomb” polyhedral mesh from a tetrahedral mesh.
from
http://www.openfoam.com/features/mesh-generation.php
elvis is offline   Reply With Quote
pointwise, shm, snappyhexmesh, structured mesh
[snappyHexMesh] Creating very fine, high accuracy mesh with snappyHexMesh JD_Welch OpenFOAM Meshing & Mesh Conversion 10 July 5, 2023 12:50
[snappyHexMesh] problem with snappyHexMesh kanes OpenFOAM Meshing & Mesh Conversion 10 January 26, 2016 07:11
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 08:05
