[snappyHexMesh] processorWeights problem with snappyhexmesh in parallel
Old   July 7, 2011, 11:05
Default processorWeights problem with snappyhexmesh in parallel
Oskar
oskar is on a distinguished road
I can't seem to get any effect out of using decomposeParDict->parMetisCoeffs->processorWeights values when running snappyhexmesh in parallel. I haven't tried running serial though.
At least in parallel sHM seems to always balance to equal cell count per process, and totally ignore the processorWeights values.
Does anyone know if this is supposed to work?
If so, what might be my problem? parMetis use?
At least to my knowledge, sHM doesn't do any balancing itself, but uses third-party (parMetis) for it, so the problem probably isn't with sHM itself?
edit: using openfoam 1.7.x
oskar is offline   Reply With Quote
parmetis parallel weight
[snappyHexMesh] Running snappyHexMesh in parallel creates new time directories hconel OpenFOAM Meshing & Mesh Conversion 5 September 27, 2022 16:20
Problem with foam-extend 4.0 ggi parallel run Metikurke OpenFOAM Running, Solving & CFD 1 December 6, 2018 16:51
Problem in foam-extend 4.0 ggi parallel run Metikurke OpenFOAM Running, Solving & CFD 0 February 20, 2018 07:34
SnappyHexMesh OF-1.6-ext crashes on a parallel run norman1981 OpenFOAM Bugs 5 December 7, 2011 13:48
[snappyHexMesh] Parallel mesh generation using snappyHexMesh aki_yafuji OpenFOAM Meshing & Mesh Conversion 0 December 25, 2010 04:49
