[snappyHexMesh] How do I view results?
Old   June 26, 2011, 23:42
Default How do I view results?
RygeltheXVI is on a distinguished road
Greetings,
I'm new to using snappyHexMesh - once the utility is run how do I view the resulting mesh?
I've had a bit of a look through the forums and it seems paraView may have problems as the cells arn't hexs.
The commands I entered were:
blockMesh
decomposePar
foamJob -p -s snappyHexMesh
reconstructParMesh -mergeTol 1e-06 -time 1
reconstructParMesh -mergeTol 1e-06 -time 2
reconstructParMesh -mergeTol 1e-06 -time 3
paraFoam
But this just shows me the initial Mesh.
Thanks
RygeltheXVI is offline   Reply With Quote
Old   June 27, 2011, 01:45
Default Partial Success
I had partial success with the command (run form the case directory);
[IMG]file:///tmp/moz-screenshot.jpg[/IMG] p { margin-bottom: 0.08in; } foamToVTK
Then from paraViewer opening the resulting files in the VTK folder manually.
However it still doesn't seem to be showing the internal mesh of the resulting bounding region, just the mesh of the surface of the .stl object.
Still this is some progress. Baby steps and all that...
viewing snappyhexmesh
Problem: Very long "write" time (~2h-3h) for results and transient results Shawn_A CFX 16 April 12, 2016 21:49
View Conduction, Convection, Radiation Heat Transfer (Watt) in results EGY CFX 0 March 28, 2016 12:18
Using results from experiment studygroups2000 FLUENT 0 November 25, 2015 18:29
Transient Run - Output "Time" in partial results? evcelica CFX 2 May 16, 2012 22:36
View Sampling Results Smed OpenFOAM Post-Processing 1 January 4, 2012 05:21
