June 22, 2011, 11:21 |
Boolean operation in Gmsh?
Robin
Rep Power: 15 |
Hi everyone,
I have been adviced to use Gmsh instead of Gambit to make an OpenFOAM study, the interface is great and looks like Gambit however I was wondering if there were any possible operations such as doing the instersection between two solids. For exemple if I have two cylinders crossing each others and I want to delete the intersected part inside the volume, how can I do that? (I know there is a split function but it is not available for surfaces). Thank you for your answers and the CFD online community. |
August 17, 2011, 09:46 |
Hansjoerg Seybold
Rep Power: 17 |
No,
cheers hj |
boolean, cylinders, gmsh, split |
loading issue libraries:libsimpleFunctionObjects.so libsimpleSwakFunctionObjects.so | immortality | OpenFOAM Pre-Processing | 15 | April 7, 2024 12:35 |
[Gmsh] Gmsh Boolean Subtraction on .stl Files | f_mdi2 | OpenFOAM Meshing & Mesh Conversion | 0 | October 5, 2018 15:22 |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 06:47 |
Info message -> Fluent does not start | Jenson | FLUENT | 0 | December 22, 2011 17:21 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 10:56 |
