#61 |
Subhasree
Rep Power: 12 ![]() |
Hi Everyone!,
I have been trying to mesh using snappyHexMesh a rectangular domain with a cylinder inside. Although I was able to mesh it, the surface mesh is not that good. Also the edges with layers are having bad elements. I will be using icoLagrangianFoam solver and good surface mesh is important. I am attaching the snappyHexMesh file. Can anyone look through this and tell me what can i modify to improve the mesh quality. ![]() ![]() ![]() Thanks in advance Regards Subhasree |
#62 |
Vignesh Rajendiran
Rep Power: 10 ![]() |
I got the following error when i tried to get the .eMesh file from the .stl file. Is there any problem with my openfoam installation. Do I need to reinstall the entire thing once again?
$ surfaceFeatureExtract -includedAngle 150 -writeObj constant/triSurface/airfoil.stl airfoil Usage: surfaceFeatureExtract [OPTIONS] options: -case <dir> specify alternate case directory, default is the cwd -dict <file> read control dictionary from specified location -noFunctionObjects do not execute functionObjects -srcDoc display source code in browser -doc display application documentation in browser -help print the usage extract and write surface features to file Using: OpenFOAM-3.0.1 (see www.OpenFOAM.org) Build: 3.0.1-d8a290b55d28 --> FOAM FATAL ERROR: Wrong number of arguments, expected 0 found 3 Invalid option: -writeObj Invalid option: -includedAngle FOAM exiting |
#63 |
Rep Power: 16 ![]() |
Your format for surfaceFeatureExtract is based on OF-2.1 and possibly older. The new ones from OF-2.2 require a surfaceFeatureExtractDict where you specify the includedAngle and the like... Cheers, Antimony |
[snappyHexMesh] Failed Edge Snap with box geometry and correct feature capture | thiagomarinho | OpenFOAM Meshing & Mesh Conversion | 7 | May 7, 2022 10:19 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
[snappyHexMesh] snappyHexMesh: Feature snapping of thin membrane edge | gooofy | OpenFOAM Meshing & Mesh Conversion | 7 | September 19, 2016 05:29 |
[snappyHexMesh] snappyHexMesh doesn't do feature edge snapping | wc34071209 | OpenFOAM Meshing & Mesh Conversion | 1 | May 7, 2014 17:47 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
