#41 |
Deepak Cheekati
Rep Power: 14 ![]() |
Hi everyone
![]() Are those smooth circular edges even possible? ![]() I am trying to mesh a simple cylinder.I ran snappyhexmesh many times, took all the advice available online, but of no use. ![]() Any help would be appreciated. ![]() |
#42 |
Florian
Rep Power: 16 ![]() |
Your cylinder looks like the snap phase of snappyHexMesh has not taken place, just the castellated mesh was created.
Did you reconstructParMesh/look at the correct timestep 3? |
#43 |
Deepak Cheekati
Hi Horus
I just checked it. Its looks fine now. My bad ![]() Thank You Turbulence |
#44 |
Sam Mathew
I found this thread quite helpful to have my mesh conform more to the geometry. Now, I am having trouble though, getting the prism layer extending all the way to the flow boundaries.
I would like to have something like this mesh (made using ICEM CFD) but as of now I only manage to get this one with the snappyHexMesh utility. I would be glad for some reviews. Thank you. Sam |
#45 |
Marco A. Turcios
Rep Power: 28 ![]() |
You can either make the base cartesian mesh have that kind of underlying structure (but in that case you might as well create the mesh using blockMesh, it can be done), or user layer insertion with uniform layer thickness and lots of layers. This will require some experimentation.
#46 |
Andrea Ferrari
Hi all,
i would like to extract feature edges in a particular region of my domain. So i am usign -subsetBox option to remove edges outside specified bounding box. Which is the correct syntax? the option -subsetBox ((1 1 1)(2 2 2)) does not work. thank andrea |
#47 |
#48 |
Andrea Ferrari
you are right! great, now it works. best andrea |
#49 |
Basta
Rep Power: 13 ![]() |
Dear all,,,
I have problem & I think it's related to the feature edge,, Could you help me ? http://www.cfd-online.com/Forums/ope...alve-case.html best regards, Mina |
#50 |
Dear All,
After going through this thread I have fixed some problem, but still I have some problem with edge snapping. the steps I followed is: 1) I executed blockMesh after setting up the case ( 0 cons-> ( poly, trisurf) sys), see fig 1. 2) Secondly, as Bruno's post, the surfaceFeatureExtract command has been executed. Code:
surfaceFeatureExtract -includedAngle 150 -writeObj constant/triSurface/fanGeo.stl fanGeo Code:
castellatedMesh true; snap true; addLayers false; geometry { fanGeo.stl { type triSurfaceMesh; name fanGeo; } refinementBox { type searchableBox; min (-0.4 0.2 -0.1); max (0.4 0.8 0.1); } }; // Settings for the castellatedMesh generation. castellatedMeshControls { maxLocalCells 2000000; maxGlobalCells 20000000; minRefinementCells 3; maxLoadUnbalance 0.10; nCellsBetweenLevels 5; features ( { file "fanGeo.eMesh"; level 4; } ); refinementSurfaces { fanGeo { level (4 4); } } // Resolve sharp angles resolveFeatureAngle 30; refinementRegions { } locationInMesh (0.15 0.46 1); allowFreeStandingZoneFaces true; } // Settings for the snapping. snapControls { nSmoothPatch 5; tolerance 1; nSolveIter 300; nRelaxIter 5; nFeatureSnapIter 20; } // Generic mesh quality settings. At any undoable phase these determine // where to undo. meshQualityControls { maxNonOrtho 65; maxBoundarySkewness 20; maxInternalSkewness 4; maxConcave 80; minVol 1e-13; minTetQuality 1e-30; minArea -1; minTwist 0.02; minDeterminant 0.001; minFaceWeight 0.02; minVolRatio 0.01; minTriangleTwist -1; nSmoothScale 4; errorReduction 0.75; } please help me to get the good edge snapping. Thanks, Sivakumar Last edited by wyldckat; August 22, 2013 at 10:44. Reason: Added [CODE][/CODE] |
#51 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 ![]() ![]() ![]() ![]() ![]() ![]() |
Hi Sivakumar,
The second image is too far from the blade details. I can't see how many cells you had available for adjusting the mesh to the blade. Best regards, Bruno PS: please use the "[CODE]" markers, as explained on the second link on my signature.
#52 |
Dear Bruno,
Thank you very much for your quick reply, I didnt refine any particular region so far. I am trying to make it possible to use of it. after getting some experience I want to do refining region and adding layers and so on... I used the blockMeshDict as follows Code:
convertToMeters 1; a 10; b 10; c 150; yi 0.2; yf 0.8; zi -1.55; zf 6.05; xi -0.4; xf 0.4; vertices ( ($xi $yi $zi) //0 ($xf $yi $zi) //1 ($xf $yf $zi) //2 ($xi $yf $zi) //3 ($xi $yi $zf) //4 ($xf $yi $zf) //5 ($xf $yf $zf) //6 ($xi $yf $zf) //7 ); blocks ( hex (0 1 2 3 4 5 6 7) ($a $b $c) simpleGrading (1 1 1) // is it possible can I make 3 hex boxes?? instead of 1 so that I can give more refinement for particular region? ); edges ( ); patches ( ); mergePatchPairs ( ); If you dont mind please give me some information about defining the patches. I tried as follows for another case to define patches in the blockMeshDict, but its not working. convertToMeters 1; vertices ( (-0.2 0 -1.5) (0.7 0 -1.5) (0.7 0.8 -1.5) (-0.2 0.8 -1.5) (-0.2 0 -0.1) (0.7 0 -0.1) (0.7 0.8 -0.1) (-0.2 0.8 -0.1) (-0.2 0 0) (0.7 0 0) (0.7 0.8 0) (-0.2 0.8 0) (-0.2 0 0.1) (0.7 0 0.1) (0.7 0.8 0.1) (-0.2 0.8 0.1) (-0.2 0 0.2) (0.7 0 0.2) (0.7 0.8 0.2) (-0.2 0.8 0.2) (-0.2 0 6) (0.7 0 6) (0.7 0.8 6) (-0.2 0.8 6) ); blocks ( hex (0 1 2 3 4 5 6 7) (30 40 100) simpleGrading (1 1 1) hex (4 5 6 7 8 9 10 11) (30 40 20) simpleGrading (1 1 1) hex (8 9 10 11 12 13 14 15) fan (30 40 60) simpleGrading (1 1 1) hex (12 13 14 15 16 17 18 19) (30 40 20) simpleGrading (1 1 1) hex (16 17 18 19 20 21 22 23) (30 40 500) simpleGrading (1 1 1) ); boundary ( inlet { type patch; faces ( (0 3 2 1) ); } outlet { type patch; faces ( (20 21 22 23) ); } top0 { type wall; faces ( (0 1 5 4) ); } top1 { type wall; faces ( (4 5 9 8) ); } top2 { type wall; faces ( (8 9 13 12) ); } top3 { type wall; faces ( (12 13 17 16) ); } top4 { type wall; faces ( (16 17 21 20) ); } ILR0 { type cyclic; neighbourPatch ILR1; faces ( (0 4 7 3) ); } ILR1 { type cyclic; neighbourPatch ILR0; faces ( (1 5 6 2) ); } CLR0 { type cyclic; neighbourPatch CLR1; faces ( (4 8 11 7) ); } CLR1 { type cyclic; neighbourPatch CLR0; faces ( (5 9 10 6) ); } FCLR0 { type cyclic; neighbourPatch FCLR1; faces ( (12 16 19 15) ); } FCLR1 { type cyclic; neighbourPatch FCLR0; faces ( (13 17 18 14) ); } OLR0 { type cyclic; neighbourPatch OLR1; faces ( (16 20 23 19) ); } OLR1 { type cyclic; neighbourPatch OLR0; faces ( (17 21 22 18) ); } center0 { type wall; faces ( (3 7 6 2) ); } center1 { type wall; faces ( (7 11 10 6) ); } center2 { type wall; faces ( (15 19 18 14) ); } center3 { type wall; faces ( (19 23 22 18) ); } fan { type wall; faces ( (8 12 15 11) (11 15 14 10) (9 13 14 10) ); } ); Sivakumar Last edited by wyldckat; August 22, 2013 at 11:40. Reason: Added [CODE][/CODE] |
#53 | |
Bruno Santos
Hi Sivakumar,
There isn't much I can do with your "blockMeshDict" file. I wanted to see the zoom near the blade's edge, in order to be able to suggest anything useful. Either way, I suggest that you try to use the currently available GUIs, which I'll quote from here: http://openfoamwiki.net/index.php/Sn..._Interfaces.29 Quote:
Bruno
#54 |
Hi Bruno,
I have attached the some of the zoomed figures, Thanks, Sivakumar |
#55 |
Bruno Santos
Hi Sivakumar,
The number of cells available along the width of the blade, near this end of the blade, is far from enough. You need at least 2x the refinement that you have right now, near that end of the blade, for snappyHexMesh to be able to give you a barely good mesh. The other detail is that you should keep in mind to have a good base mesh that is well aligned with the blade, if possible. I think the tutorial "incompressible/pimpleDyMFoam/wingMotion", namely the sub-folder "wingMotion_snappyHexMesh", should give you a good idea of how things work. Best regards, Bruno
#56 |
Thanks Bruno, I will have a look now.
#57 |
J.-H. Wang
Rep Power: 15 ![]() |
Hello all,
I was playing with this surfaceFeatureExtract tool today. Its pretty cool, except that I cannot seem to get it to work. In particular I am playing with flow over a cube. After the eMesh file was created, I ran snappyHexMesh and got the following error: Code:
--> FOAM FATAL IO ERROR: attempt to read beyond EOF file: /Volumes/OpenFOAM-v2.3.0-git/jui-hsienwang-2.3.x/run/cube/system/snappyHexMeshDict.castellatedMeshControls.features at line 33. From function ITstream::read(token&) in file db/IOstreams/Tstreams/ITstream.C at line 83. FOAM exiting JHW |
#58 | |
J.-H. Wang
I managed to wipe my own ass. The correct snappyHexMeshDict file should have Code:
features ( { file "cube.eMesh"; level 1; } ); Code:
features ( file "cube.eMesh"; level 1; ); JHW |
#59 | ||
Hasan K.J.
Hi All,
I have been trying to mesh this particular geometry for more than a month now, this is my final resort to ask on the forums. What ever I do the trailing edge of the airfoil is always deforming and the sides of the serrations are always having some deformity and not having the smooth finish as th top of the airfoil. Here is my SappyCode Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // castellatedMesh true; snap true; addLayers false; geometry { Blade.stl { type triSurfaceMesh; name Blade; } }; castellatedMeshControls { maxLocalCells 999999999; maxGlobalCells 999999999; minRefinementCells 10; maxLoadUnbalance 0.10; nCellsBetweenLevels 3; resolveFeatureAngle 30;//60 require high values allowFreeStandingZoneFaces true; locationInMesh (-0.0005 0.0005 0.0009); features ( { file "Blade.eMesh"; level 0; } ); refinementSurfaces { Blade { level (4 4); } } refinementRegions { Blade { mode distance; levels ((0.005 2)(0.01 1)); } } } snapControls { nSmoothPatch 10; tolerance 4; nSolveIter 300; nRelaxIter 10; nFeatureSnapIter 20; implicitFeatureSnap false; explicitFeatureSnap true; multiRegionFeatureSnap true; //only for explicitFeature, Deafault = false } addLayersControls { relativeSizes true; layers { Blade_solid { nSurfaceLayers 5; } } expansionRatio 1.0; finalLayerThickness 0.8; minThickness 0.001;//1e-15 nGrow 0; featureAngle 90;//180 nRelaxIter 100;//15 nSmoothSurfaceNormals 10;//1 nSmoothNormals 30; nSmoothThickness 30;//10 maxFaceThicknessRatio 0.5; maxThicknessToMedialRatio 0.3; minMedianAxisAngle 90; nBufferCellsNoExtrude 0; nLayerIter 50; } meshQualityControls { maxNonOrtho 65; maxBoundarySkewness 20; maxInternalSkewness 4; maxConcave 80; minVol 1e-13; minTetQuality 1e-9;//1e-30 minArea -1; minTwist 0.05;//0.02 minDeterminant 0.001; minFaceWeight 0.05;//0.02 minVolRatio 0.01; minTriangleTwist -1; nSmoothScale 4; errorReduction 0.75; relaxed { maxNonOrtho 75;// 180 to disable } } debug 0; mergeTolerance 1E-6; // ************************************************************************* // Quote:
Even the surface layers were showing deformities now and then, about 70% of the airfoil had good surfacelayer mesh but suddenly there is a deformity similar to disscussed by artur, so as now I have planned to follow Arthurs suggestion but If there is any other way to get the surface mesh sorted in snappyHexMesh itself I will be very happy. Quote:
This is just very fine tuning of the surface finish of the mesh as we are interested in the surface boundary layer of the airfoil, the mesh on the surface of the airfoil is absolutely fine only when close to the trailing edge and the thin trailing edge that is causing this issue Thanks for your time and efforts, Hasan K.J
"Real knowledge is to know the extent of one's ignorance." - Confucius |
#60 |
Bruno Santos
Greetings Hasan K.J,
I've had this post of yours on my to-do list for quite sometime now and unfortunately I only managed to take a look into it today ![]() Without access to the geometry or at least a test case to work with, I will have to guess that:
The other possibility that comes to mind is that you should have a refinement region better refined: Code:
Blade { mode distance; levels ((0.0005 4)(0.001 3)(0.005 2)(0.01 1)); } The other possibilities that comes to mind are:
Bruno
[snappyHexMesh] Failed Edge Snap with box geometry and correct feature capture | thiagomarinho | OpenFOAM Meshing & Mesh Conversion | 7 | May 7, 2022 09:19 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[snappyHexMesh] snappyHexMesh: Feature snapping of thin membrane edge | gooofy | OpenFOAM Meshing & Mesh Conversion | 7 | September 19, 2016 04:29 |
[snappyHexMesh] snappyHexMesh doesn't do feature edge snapping | wc34071209 | OpenFOAM Meshing & Mesh Conversion | 1 | May 7, 2014 16:47 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
