July 29, 2019, 05:33 |
#21 |
Rep Power: 11 |
I'm afraid, this is one of the issues caused by the incomplete development of MegaCads. But, don't take those too serious as there is normally an easy workaround for any such problem. First, I suggest you to start off always as follows:
1 0 import_geometry <format> "$PATH_TO_YOUR_FILE" 0 0 = <choose_name>
July 29, 2019, 05:51 |
Current download link BLoOMYBOXX v2.5
#22 |
Rep Power: 11 |
https://www.researchgate.net/publica...OMYBOXX_V25tar
I will provide the latest version (2.7) in the coming weeks |
September 10, 2019, 10:44 |
#23 |
Nick
Rep Power: 17 |
Hello everyone,
I seem to have some kind of difficulties while trying to import the naca12.dat file into MegaCads in order to begin the tutorial sessions. What i am currently doing is this: 1) File > Project > Open > navigate into the directory where i ve placed the .dat file 2) File > Init that directory I am getting two extra files generated, afterwards, namely SAVE_PROC_FILE and save.sty files. However, when im trying to File > Import > Point Data, i dont get any pop up window to choose from. P.S i also get an ENTITY_FILE once i terminate the session. Any suggestions? Thanks Nick |
September 10, 2019, 10:55 |
#24 | |
Rep Power: 11 |
Hi Nick, 1) The project directory is the one where, either, your SAVE_PROC_FILE already exists (then you don't really need to initialise but just "restart" via "Edit -> Edit Script File... -> Restart"), or, a new SAVE_PROC_FILE will be created as a result. The SAVE_PROC_FILE is the one you want to play with. 2) "Init" will create the SAVE_PROC_FILE if there is none If you still don't get it work, just send me an example dat file and I'll post the command to read it into the GUI. good luck Last edited by NablaDyn; September 16, 2019 at 08:00. |
September 10, 2019, 12:06 |
#25 |
Nick
Rep Power: 17 |
Dear Martin,
Thanks for the prompt reply! The thing is that i dont get a popup window, after i choose File > Import > Point Data, or any other type of file (IGES, STL, ICEM) for that matter, even though, i am within my working directory and SAVE_PROC_FILE (either the old one or the new one after init) is present. By the way im trying to attach the .dat file (naca12.dat which is found inside the CGRID_2D folder of the software) but it seems to be rejected for some reason. Thanks, Nick |
September 10, 2019, 17:59 |
#26 | |
Rep Power: 11 |
Don't try to use the GUI for file management. As I mentioned somewhere in the forum, MegaCads is a bit buggy and thus some GUI features (especially file management-related) do not behave as expected. For import/export tasks you should refrain to a text editor of your choice (I prefer Gedit with "octave" syntax highlighting) and simply put the respective commands into your SAVE_PROC_FILE manually. For instance: Code:
1 0 def_working_plane 0 Code:
2 0 read_data "$PATH_TO_DAT_FILE" 0 0 = <choose_significant_name> I recommend you to set up your SAVE_PROC_FILE in the project folder such that it consists only of the above-mentioned commands (adapt $PATH and <name>) and see what happens when you execute from GUI "edit > restart... > restart". Last edited by NablaDyn; September 10, 2019 at 18:00. Reason: Typo |
September 15, 2019, 12:52 |
#27 |
Nick
Rep Power: 17 |
Dear Martin,
Thanks for the tip! There seems to be a beam of light at the end of the tunnel By doing so, the shape of the airfoil was loaded up, so, for the time being, i m going through this current SAVE_PROC_FILE, the pre made one (situated inside the tutorials folder), which already contains the mesh and the turotial.pdf file (which unfortunately is written in german , in order to figure it out! Cheers again! |
September 16, 2019, 08:02 |
#28 | |
Rep Power: 11 |
Ok, the correct location of the "Restart" button is "Edit -> Edit Script File... -> Restart". I corrected it already in the respective post above (#24)... Sorry for the inconvenience... |
September 23, 2019, 08:00 |
#29 |
Nick
Rep Power: 17 |
Hey there guys once more.
Unless im wrong and just as it has been mentioned in previous posts, i feel like the software functions, mainly, through the use of scripting, in the SAVE_PROC_FILE, apart from the visualization options, at the bottom section of the gui. So to speak, actions such as splitting, defining polygons, joining curves etc are being deployed through adding the respective command in the aforementioned file and then hitting the restart button from within mcads. If this is indeed the case, is there any commands line up, with all of the choices (related to the existing gui buttons), so that we know what is the correct syntax etc, in order to implement it in the script file? I mean, for instance, after going through the first tutorial, there has to be a spline created with the use of the points, loaded from the naca12.dat file. The respective command is: 4 1 spline_polygon P_3(1) = P_4, where 4 is the incremented number (after defining the working plane, reading the .dat file and perhaps defining as variable the airfoil points (?). By clicking the Spline Button from Cad/Parametrize/Spline, as the tutorial dictates, nothing happens, when i do click the airfoil entity. So i should be able to script it down but then again how are we supposed to know what to script, i.e the spline_polygon syntax as well as the (1) next to the process 3 (P_3). Thank again! Nick |
September 23, 2019, 08:30 |
#30 | ||||
Rep Power: 11 |
Navigate to "Documentation">"Index" and find what you are looking for. Sometimes even a google search takes you there. Quote:
1. LMB entity A 2. RMB entity A then 3. LMB entity B 4. RMB entity B then, hit "Exec". You should now see the spline, probably wrongly orientated in the GUI. Also, the command should have been appended to your SAVE_PROC_FILE by MEGACADS. You can check it by looking at your restart file ("Edit>Edit Script File..."). "START"/"POSITIV" relate to the directions of the spline with respect to the entities used for construction (A,B) and can be changed manually in the SAVE_PROC_FILE once the process has been appended. To find the just performed command in your SAVE_PROC_FILE, open - or if already open, refresh - the SAVE_PROC_FILE in your text editor. Be careful not interfere with your SAVE_PROC_FILE whilst using the GUI. Otherwise changes/commands might not take effect or the GUI might crash. By the way, a GUI crash happens always at the same point in your script, there is something wrong with your command or the used entities. You can use the "break_if 1" command to halt MEGACADS during restart at a point of your choice, e.g. "1000 0 break_if 1" As you see, this is also a nice way to learn a new command. First execute it in the GUI and let MEGACADS append it to your SAVE_PROC_FILE. You can then simply adapt the obtained command line to your needs and reuse it as you wish. |
September 23, 2019, 08:39 |
#31 |
Rep Power: 11 |
I opened up a new Thread for usage-related issues concerning MEGACADS:
How to use MEGACADS (DLR) |
September 23, 2019, 09:02 |
#32 |
Nick
Rep Power: 17 |
Dear NablaDyn,
Thanks for the prompt reply. I will go through the index which seems to be what i was really looking for. You were correct, regarding the spline option inside the gui. I simply didnt right click properly! Cheers for all your effort and the help provided so far! Nick |
[CAD formats] MegaCads Installation on Ubuntu | NablaDyn | OpenFOAM Meshing & Mesh Conversion | 13 | May 29, 2020 14:17 |
Free structured grid generator: MegaCads | Olaf Brodersen | Main CFD Forum | 0 | February 11, 1999 04:16 |
