May 24, 2011, 17:44 |
Meshing a weird pipe
lazersos@gmail.com
Rep Power: 15 |
I'd like to explore flow through a twisted pipe. Now I can readily output the coordinates of a series of nested surfaces in the pipe. I'd like to generate a 3D mesh for this coordinate system. I've thought about just constructing the points, faces, owners, boundary and neighbors files in my pre-processor but I got to the owners/neighbors part and realized that it was going to be a bit of a headache. Additionally, my deffinition of a pipe has an axial gridpoint which I believe could stand to be converted into a more cartesian mesh. Has anyone dealt with this problem. Thanks, I'm an openFOAM newbie.
PS- I've attached a plot of the points and the radial surfaces, there are ~100 radial surfaces, I've only chosen a few. Oh and I plan to have flow in one end and out the other. |
May 25, 2011, 13:47 |
Update
lazersos@gmail.com
Rep Power: 15 |
Ok so I figured it would be simplest to create a blockMeshDict file and let blockMesh take it from there. I tried to define my problem by specifying the points on the outboard, top, inboard and bottom of the shape then defining the edges using a polyMesh. Unfortuantely this doesn't seem to be working:
FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1.000000; vertices ( // Inlet (nv=0) (4.124254 0.000000 0.000000) (3.697167 0.000000 0.904083) (3.357811 0.000000 0.277534) (3.697167 0.000000 -0.904083) // Outlet (nv=8) (3.336592 2.424176 0.000000) (2.991071 2.173140 0.904083) (2.716526 1.973672 0.277534) (2.991071 2.173140 -0.904083) ); blocks ( hex ( 0 1 2 3 4 5 6 7 ) ( 30 30 30 ) simpleGrading (10 10 10) ); edges ( // Inlet (nv=0) polySpline 0 1 ( ( 4.098676 0.000000 0.272565 ) ( 4.027965 0.000000 0.519575 ) ( 3.927305 0.000000 0.713843 ) ( 3.812816 0.000000 0.845920 ) ) polySpline 1 2 ( ( 3.591181 0.000000 0.864608 ) ( 3.499359 0.000000 0.729783 ) ( 3.419496 0.000000 0.527036 ) ) polySpline 2 3 ( ( 3.333465 0.000000 0.000000 ) ( 3.357811 0.000000 -0.277534 ) ( 3.419496 0.000000 -0.527036 ) ( 3.499359 0.000000 -0.729783 ) ( 3.591181 0.000000 -0.864608 ) ) polySpline 3 0 ( ( 3.812816 0.000000 -0.845920 ) ( 3.927305 0.000000 -0.713843 ) ( 4.027965 0.000000 -0.519575 ) ( 4.098676 0.000000 -0.272565 ) ) // Outlet (nv=8) polySpline 4 5 ( ( 3.315899 2.409141 0.272565 ) ( 3.258692 2.367579 0.519575 ) ( 3.177257 2.308412 0.713843 ) ( 3.084633 2.241117 0.845920 ) ) polySpline 5 6 ( ( 2.905327 2.110843 0.864608 ) ( 2.831041 2.056872 0.729783 ) ( 2.766431 2.009929 0.527036 ) ) polySpline 6 7 ( ( 2.696830 1.959361 0.000000 ) ( 2.716526 1.973672 -0.277534 ) ( 2.766431 2.009929 -0.527036 ) ( 2.831041 2.056872 -0.729783 ) ( 2.905327 2.110843 -0.864608 ) ) polySpline 7 4 ( ( 3.084633 2.241117 -0.845920 ) ( 3.177257 2.308412 -0.713843 ) ( 3.258692 2.367579 -0.519575 ) ( 3.315899 2.409141 -0.272565 ) ) // Outboard (nu=1) polySpline 0 4 ( ( 4.124254 0.000000 0.000000 ) ( 4.175213 0.375776 -0.174579 ) ( 4.277976 0.776338 -0.207229 ) ( 4.330820 1.195230 -0.098508 ) ( 4.206246 1.578631 0.098508 ) ( 3.917275 1.886460 0.207229 ) ( 3.598694 2.150119 0.174579 ) ( 3.336592 2.424176 0.000000 ) ) // Top (nu=6) polySpline 1 5 ( ( 3.697167 0.000000 0.904083 ) ( 3.498043 0.314830 0.809446 ) ( 3.397586 0.616571 0.617582 ) ( 3.430537 0.946768 0.450487 ) ( 3.474680 1.304069 0.408822 ) ( 3.485515 1.678536 0.527167 ) ( 3.323857 1.985912 0.758950 ) ( 2.991071 2.173140 0.904083 ) ) // Inboard (nu=10) polySpline 2 6 ( ( 3.357811 0.000000 0.277534 ) ( 3.182222 0.286405 0.499018 ) ( 2.882962 0.523181 0.477973 ) ( 2.690070 0.742412 0.255634 ) ( 2.673719 1.003464 -0.012463 ) ( 2.770921 1.334405 -0.123277 ) ( 2.828113 1.689719 -0.006381 ) ( 2.716526 1.973672 0.277534 ) ) // Bottom (nu=16) polySpline 3 7 ( ( 3.697167 0.000000 -0.904083 ) ( 3.856346 0.347077 -0.758950 ) ( 3.806460 0.690771 -0.527167 ) ( 3.577588 0.987351 -0.408822 ) ( 3.331859 1.250467 -0.450487 ) ( 3.111116 1.498235 -0.617582 ) ( 3.015028 1.801395 -0.809446 ) ( 2.991071 2.173140 -0.904083 ) ) ); patches ( wall pipe_edge ( ( 0 4 5 6) ( 1 5 6 2) ( 2 6 7 3) ( 3 7 4 0) ) patch inlet ( ( 0 1 2 3) ) patch outlet ( ( 4 5 6 7) ) ); Code:
:3409 blockMesh -case test /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.7.1-03e7e056c215 Exec : blockMesh -case test Date : May 25 2011 Time : 12:42:49 Host : sunfire20.pppl.gov PID : 5270 Case : ./test nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Creating block mesh from "./test/constant/polyMesh/blockMeshDict" Creating blockCorners Creating curved edges Creating blocks Creating patches Creating block mesh topology --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.303366 for face 0 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.205269 for face 1 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.257956 for face 2 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.246229 for face 3 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.25246 for face 4 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -0.252461 for face 5 --> FOAM Warning : From function blockMesh::createTopology(IOdictionary&) in file createTopology.C at line 397 negative volume block : 0, probably defined inside-out Default patch type set to empty --> FOAM FATAL ERROR: face 0 in patch 0 does not have neighbour cell face: 4(0 4 5 6) From function polyMesh::facePatchFaceCells(const faceList& patchFaces,const labelListList& pointCells,const faceListList& cellsFaceShapes,const label patchID) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 124. FOAM aborting |
May 25, 2011, 14:29 |
lazersos@gmail.com
Rep Power: 15 |
OK fixed it. First my ordering of the initial gridpoints was wrong. I was ordering them in a counterclockwise fashion and that needed to be switch to clockwise (along with fixing an error in the points themselves). Then one of my wall patches was wrong. Now I just need to get paraview compiled on system to see if the resulting grid looks anything like what I want.
[ICEM] ICEM "U" shaped pipe meshing | mshaux | ANSYS Meshing & Geometry | 2 | April 12, 2016 10:06 |
[ICEM] Hexa meshing branched pipe with different angles about its perimeter | fascinatedbyCFD | ANSYS Meshing & Geometry | 1 | November 19, 2015 11:11 |
[ICEM] Pipe 90 elbow joint meshing issue | sihaqqi | ANSYS Meshing & Geometry | 25 | April 17, 2015 05:59 |
[GAMBIT] GAMBIT Meshing of Pipe with Holes Perpendiculer to Flow Stream | rocketman1151 | ANSYS Meshing & Geometry | 7 | November 30, 2011 03:39 |
Meshing of circular pipe in CFX-mesh | Fatnes | CFX | 3 | March 27, 2009 07:29 |
