[snappyHexMesh] SnappyHexMesh Meshing inside a cylinder
Old   March 10, 2011, 14:32
Default SnappyHexMesh Meshing inside a cylinder
Diauddin Nammari
nammari is on a distinguished road
Good evening Foamers,
I was wondering if anyone could help, I am trying to model a tank in simple domain. I am trying to analyse the recirculations zones inside the cylinder and outside.
So far it has been straight forwards to create a solid cylinder, but creating a hollow cylinder using snappyhexmesh seems a wee bit tricky, I haven't managed so far, does anyone have any ideas ? Much appreciated
Dia
nammari is offline   Reply With Quote
Old   March 11, 2011, 08:25
FG_HSRM is on a distinguished road
Hi Dia,
Maybe, you can give more details about your geometry, like is the inside domain connected with the outside domain?
It also would help to make clear, which procedure you are using.
Regards, fritz
FG_HSRM is offline   Reply With Quote
Old   March 11, 2011, 10:46
Diauddin Nammari
Hi Fritz,
Thanks for answering back, that is what I want indeed that the inside domain is connected to the outside domain. Such that I would allow the "wind" to wizz inside the the tank( storage tank) and outside it.
If you don't mind what do you mean by procedure ? I am planning to test out a few solvers, and play around with windfoam.
As you can get I am trying to avoid "creating" the blockMesh dict by hand, or trying to use other software to create the geometry.
Cheers
Dia
Old   March 11, 2011, 11:48
The geometry import is exactly what I meant with procedure, sorry for my unclear question. Until now, I just can say that you have to make sure in the snappyHEXMeshDict that the "locationInMesh" is carefully placed and there shouldn't be a boundary between the two parts of the domain.
Besides, what exactly is the problem?
Old   March 11, 2011, 15:10
Diauddin Nammari
I was trying to create a hollow cylinder with the opening into the domain. So far the cylinders or objects I create are closed. That is my issue. Not how to do that.
Cheers
Dia
Old   March 11, 2011, 20:49
Then, I don't understand your problem. It's absolutely the same.
hollowcylinder
[snappyHexMesh] Problems with scaling meshes when meshing with SnappyHexmesh Bnitter OpenFOAM Meshing & Mesh Conversion 1 November 15, 2018 09:26
[Gmsh] 3D Free surface flow past circular cylinder meshing using GMSH arieljeds OpenFOAM Meshing & Mesh Conversion 7 January 14, 2017 13:57
[snappyHexMesh] Inside and outside mesh with snappyhexmesh nzy102 OpenFOAM Meshing & Mesh Conversion 21 February 16, 2016 17:42
simulation of piston motion inside a hydraulic cylinder mosman FLUENT 0 August 6, 2011 16:44
2D planar cylinder meshing problem saisanthoshm88 ANSYS Meshing & Geometry 15 December 27, 2010 12:14
