[snappyHexMesh] SnappyHexMesh fails with internal Zones
Old   January 24, 2011, 08:04
Default SnappyHexMesh fails with internal Zones
Christoph Hossfeld
chossfeld is on a distinguished road
Hello all,
I got a strange behaviour with snappyHexMesh. I have defined two STL-geometries. See Bild4 bild4.gif . Here the blue shape if the main shape. The gray inside should be used as a zone. As shown with the orange cells, this works fine except some cells, which are located in the nowhere (bild3 bild3.gif ) in the middle of the zone shape. With other words: These cells belong to the internal zone, but where not inside the "zone"-stl. I have tried different background meshes, different refinement level and blocks and so on. I have no idea, why snappyHexMesh does the zones like this. There is no logic. I attach two additional pics.
Can someone help me out?
Christoph
chossfeld is offline   Reply With Quote
Old   January 27, 2011, 09:29
Default issue solved
Christoph Hossfeld
I just have done the internal zones with new a CAD-model and exported this to STL. Now everything works fine.
BUT I do not know why. The old STL passed every check and was closed.
[snappyHexMesh] SnappyHexMesh fails to create patches of .stl files WernerW OpenFOAM Meshing & Mesh Conversion 4 September 26, 2017 01:59
[Other] Multiple internal wall an fluid zones miles_davis OpenFOAM Meshing & Mesh Conversion 11 November 28, 2016 08:11
[snappyHexMesh] Pipe flow / Internal fluid dynamics with SnappyHexMesh denner OpenFOAM Meshing & Mesh Conversion 3 October 13, 2011 10:24
[snappyHexMesh] internal mesh with snappyHexMesh romant OpenFOAM Meshing & Mesh Conversion 2 August 11, 2009 06:12
1.6.x -> snappyHexMesh in parallel fails ... podallaire OpenFOAM Bugs 11 August 4, 2009 14:57
