[blockMesh] Mesh refinement for a cylindrical mesh
Old   June 20, 2018, 14:06
Ben 017
Ben UWIHANGANYE is on a distinguished road
I thank you Yage,
Though the exercise is still not working for me but at least you have been with me.
now when i add this in my blockMeshDict:
solid
type wall;
faces ();
and run the blockMesh it brings errors of:
-> FOAM FATAL IO ERROR:
keyword faces is undefined in dictionary ".solid"
file: .solid at line 83.
From function const Foam::entry& Foam::dictionary::lookupEntry(const Foam::word&, bool, bool) const
in file db/dictionary/dictionary.C at line 441.
FOAM exiting
May you try the case for me(Find attached updated case), so that we can be done at once? instead of keeping posting.
I reduced the background to (25 10 0.1)
I will be happy for support.
Regard!
Ben UWIHANGANYE is offline   Reply With Quote
Old   June 20, 2018, 16:58
Yage
Yage is on a distinguished road
Originally Posted by Ben UWIHANGANYE View Post
I thank you Yage,
Regard!
I cannot since I am reading through a mobile device.
See attached
There is mistype in toposetdict, change the "c0" to "solid"
Yage is offline   Reply With Quote
Old   June 21, 2018, 02:34
Ben 017
Yes, my ultimate goal is to simulate flow over that cylinder? (stationary and oscillating).
I thought that cylinder will be immersed not body fitted? Does it sound feasible?
Finally I got that cylinder in my paraview(see attached images). the problem were to not include Zones in paraview. Then is there away i can move that cylinder?(oscillating motion). which codes should i use? can mysetField dictionary help?
Say if the solid region eta=1 and fluid region =0, is there a way i can alternate eta to move that cylinder or? (eta: 0 0 0 0 1 1 1 1 1 0 0 0.....)
Just advise me how i can move that cylinder without dynamic mesh.
Thank you!
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[snappyHexMesh] problems generating clean mesh Christian_tt OpenFOAM Meshing & Mesh Conversion 2 June 20, 2019 06:39
[snappyHexMesh] Removing further cells after SHM zonda OpenFOAM Meshing & Mesh Conversion 14 September 15, 2017 08:50
[snappyHexMesh] snappyHexMesh & Mesh around a missile sasanghomi OpenFOAM Meshing & Mesh Conversion 2 October 15, 2014 20:54
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
