[blockMesh] blockMesh: symbol lookup error
Old   January 6, 2011, 08:42
Default blockMesh: symbol lookup error
Vadims Geza
Vadims.geza is on a distinguished road
Hello OF users!
I have problem, after new installation of OF 171, blockmesh would not run saying:
blockMesh: symbol lookup error: /home/OpenFOAM/OpenFOAM-1.7.1/lib/linuxGccDPOpt/libfiniteVolume.so: undefined symbol: _ZTIN4Foam16regionPropertiesE
the same error running splitMeshRegions, maybe for some other applications as well. Does anybody have any idea?
Thanks in advance!
Vadims.geza is offline   Reply With Quote
Old   November 1, 2013, 01:58
Srivathsan N
Sherlock_1812 is on a distinguished road
I know this is an old post but I am also getting a similar error. I have just compiled a BC without errors and now when i run blockMesh with that boundary condition in place i get:
blockMesh: symbol lookup error: /home/srivathsan/OpenFOAM/srivathsan-2.1.1/platforms/linuxGccDPOpt/lib/libfiniteVolume.so: undefined symbol: _ZTIN4Foam35newDirectionMixedFvPatchVectorFieldE
Were you able to correct the error? What is the problem here?
Regards,
Srivaths
Sherlock_1812 is offline   Reply With Quote
Old   November 1, 2013, 20:04
Lieven
Lieven will become famous soon enough
If I'm not mistaking, you get this error when you don't include the library in the controlDict-file. So adding something like:
libs
        "libnew1.so"
        "libnew2.so"
to the controlDict-file should solve the problem.
You can find more info at http://www.openfoam.org/docs/user/co...plications.php
Cheers,
Lieven
Lieven is offline   Reply With Quote
Old   November 4, 2013, 01:30
Srivathsan N
Hi Lieven,
Thank you. I understand what you've written.
I wrote my BC as a derived boundary condition and compiled it in finiteVolume/fields/fvPatchFields/derived/myNewBC (this is in FOAM_USER src directory). I made the necessary additions to the 'Make' folder in the finite volume directory and gave a wmake. Shouldn't this be enough?
I've added libfiniteVolume.so to the controlDict of my case file too, but I get the same error. I'm missing some vital point w.r.to linking libraries. Can't figure out what.
Regards,
Srivaths
Old   November 6, 2013, 06:48
Lieven
Hi Sherlock,
Have you solved the problem.
What do you mean exactly by 'finite volume directory'?
Could you post your options-file from the Make folder?
Cheers,
Lieven
Old   November 6, 2013, 07:26
Srivathsan N
Hi Lieven,
I've attached my options file. I am not sure what to add in the EXE_INC and EXE_LIBS. The boundary condition is named 'newDirectionMixed' and is present in my solver directory.
Can you spot where I've gone wrong?
Thanks.
File Type: txt options.txt (462 Bytes, 44 views)
Regards,
Srivaths
Old   September 21, 2018, 11:18
Default blockMesh: symbol lookup error.
Sunil
sunilkonatham is on a distinguished road
Hi Srivathsan,
This is 5 years back, but I'm facing same issue now.
Same is the case with me, I have created my own boundary condition in finite volume directory and compiled it with wmake, when I run any command like blockMesh or icoFoam or any other solver it is showing me same error, is your issue solved back then? Can you please share your experience?
Thanks,
Sunil.
sunilkonatham is offline   Reply With Quote
Caffa 3D code Waliur Rahman Main CFD Forum 0 May 29, 2018 01:53
Mesquite - Adaptive mesh refinement / coarsening? philippose OpenFOAM Running, Solving & CFD 94 January 27, 2016 10:40
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 21:30
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
