[Commercial meshers] gambitToFoam mesh convertion error
Old   January 1, 2011, 01:19
Unhappy gambitToFoam mesh convertion error
Santiago
gascortado is on a distinguished road
I'm trying to convert a .neu mesh from gambit and after creating a new case directory I get a segmentation error like this:
Default patch type set to empty
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/santiago/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigSegv::sigSegvHandler(int) in "/home/santiago/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted:
#3 Foam:olyMesh:olyMesh(Foam::IOobject const&, Foam::Xfer<Foam::Field<Foam::Vector<double> > > const&, Foam::List<Foam::cellShape> const&, Foam::List<Foam::List<Foam::face> > const&, Foam::List<Foam::word> const&, Foam::List<Foam::word> const&, Foam::word const&, Foam::word const&, Foam::List<Foam::word> const&, bool) in "/home/santiago/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
in "/home/santiago/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/gambitToFoam"
#5 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/i386/elf/start.S:122
Segmentation fault
Any suggestions on how I should proceed will be very appreciated. Thanks
gascortado is offline   Reply With Quote
Old   January 19, 2011, 06:51
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Prefer importing your mesh as .msh file (Gambit side)
Then in OF use: fluentMeshToFoam or fluent3DMesToFoam (if you used the tpoly utility from tgrid-->hanging nodes)
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
gambit to foam mesh
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 05:53
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 21:30
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 03:32
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
