October 13, 2010, 05:10 |
sMH refinement level
CFD user
Rep Power: 16 |
Hi everyone,
I am trying to study flow in a porous region, which is attached on a different surface. I have defined the porous region in the sHMDict file by a searchable box, specifying the minimum and the maximum co-ordinates. Again, I have also defined another region (which is actually the wake region), by a searchable box, since I want to study the variation of parameters (velocity and pressure) in this region also. In the sHMDict file, when I set the refinement level of my surface to 3, the refinement region of my porous zone as 5 and that of the wake region as 3, I get a good mesh when I run the blockMesh and sMH. Now, I wanted to move the cooler vertically by 2 m (still very much in the wake region), but changed the refinement level of the wake region to 2. This time, when I ran sMH, no porous zone was detected. There were absolutely no other changes in any of the dimensions or refinement regions. I am posting the details below: When I got all the surfaces: geometry { turbine.stl { type triSurfaceMesh; regions { turbine { name turbine; } } } porouszone { type searchableBox; min (7500 0 0); max (7594 1172 1220); } wake { type searchableBox; min (-3000 -6000 0); max (30000 5000 4000); } refinementSurfaces { turbine.stl { level (2 2); // Surface-wise min and max refinement level regions { turbine { level (3 3); } } } } refinementRegions { porouszone { mode inside; levels ((1.0 5)); } wake { mode inside; levels ((1.0 3)); } } When the porouszone was not detected (I'm highlighting the changes in colour)-- I did the refinement region changes, since the sMH was taking a lot of time for the generation of the mesh. geometry { turbine.stl { type triSurfaceMesh; regions { turbine { name turbine; } } } porouszone { type searchableBox; min (7500 2000 0); max (7594 3172 1220); } wake { type searchableBox; min (-3000 -6000 0); max (30000 5000 4000); } refinementSurfaces { turbine.stl { level (2 2); // Surface-wise min and max refinement level regions { turbine { level (3 3); } } } } refinementRegions { porouszone { mode inside; levels ((1.0 5)); } wake { mode inside; levels ((1.0 2)); } } The cell size in each direction is 1000mm and the block mesh initial created is sufficiently big to accomodate the geometry. Can someone help me out with this please... I will be so grateful.
Thanks, |
refinement, snappyhexmesh |
[snappyHexMesh] SnappyHexMesh running killed! | Mark JIN | OpenFOAM Meshing & Mesh Conversion | 7 | June 14, 2022 02:37 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 10:42 |
[snappyHexMesh] Edge Refinement | fracasce | OpenFOAM Meshing & Mesh Conversion | 3 | December 2, 2017 14:30 |
[snappyHexMesh] Adding layers goes wrong with SnappyHexMesh | Elise | OpenFOAM Meshing & Mesh Conversion | 1 | April 22, 2013 03:32 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 04:23 |
