[snappyHexMesh] Two-dimensional (2D) snappyHexMesh operation.
Old   September 28, 2010, 16:05
Default Two-dimensional (2D) snappyHexMesh operation.
ms
anothr_acc is on a distinguished road
Hi everyone.
I am hoping to simulate flow around an object similar to a circular cylinder, in two-dimensions. I started with the (successful) motorcycle tutorial, reduced the through thickness (y-axis) dimension of my blockMesh to about 1% of the x and z dimensions and set a single cell through the thickness, with several cells along the other two dimensions. I created a closed STL surface with gmsh of my object, such that a volume was defined whose major faces (looking like circles) intersected the blockMesh walls from the tutorial; the through thickness walls joined the major faces, creating a closed volume. All seemed well on viewing the mesh: I could see a circle of small thickness, with refined cells around it.
However, snappyHexMesh refinement is refining in all three Cartesian axes, resulting in cells being generated through the thickness of the mesh when, I believe, I need to keep to a single cell through the thickness for two-dimensional analysis. Inspection of the cylinder wall shows cell splitting has occurred in the y direction, as well as splitting in the desired x and z directions.
Setting empty boundary conditions in the blockMeshDict did not prevent the refinement.
Please, is there a way to prevent refinement in one of the Cartesian axes? If I am going about this the wrong way, I'd love to know!
I'm attempting to do a similar thing to that described in the manual,
only the manual made no mention of preventing splitting through the
thickness of the paper!
I am using Build : 1.7.0-113391ee57bd, on Ubuntu Lucid 64.
All the best,
Mark.
anothr_acc is offline   Reply With Quote
snappyhexmesh 2d
loading issue libraries:libsimpleFunctionObjects.so libsimpleSwakFunctionObjects.so immortality OpenFOAM Pre-Processing 15 April 7, 2024 13:35
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing peterhess OpenFOAM Meshing & Mesh Conversion 2 January 3, 2018 03:54
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 07:47
Incompatible dimensions for operation ruben23 OpenFOAM Running, Solving & CFD 2 June 12, 2015 05:14
[snappyHexMesh] stitchMesh and snappyHexMesh gdbaldw OpenFOAM Meshing & Mesh Conversion 0 December 23, 2009 03:09
