[Gmsh] Cannot get the right mesh from gmsh
Old   August 31, 2010, 02:54
Default Cannot get the right mesh from gmsh
Jinbiao Xiong
JinBiao is on a distinguished road
Send a message via MSN to JinBiao
I am trying to generate a helical coil with gmsh. My approach is to generate a circle first and then extrude it. Below is the file for gmsh. I got errors when run checkMesh. And when I check the geometry in paraview, I found that the coil wall is not one piece. There are many small pieces which are grouped into the patch defaultFaces. Can anyone help me out? Thank you very much!!!
s1 = 1.753000E-04 ;
s3 = 8.765000E-05 ;
s2 = 4.382500E-05 ;
Cx = 7.350000E-03 ;
Cy = 0.000000E+00 ;
Cz = 0.000000E+00 ;
R1 = 8.765000E-04 ;
R2 = 8.765000E-04 ;
dh = 5.950000E-04 ;
Point (1) = { Cx, Cy, Cz,s1};
Point (2) = { Cx+R1, Cy, Cz,s1};
Point (3) = { Cx, Cy+R1, Cz,s1};
Point (4) = { Cx-R1, Cy, Cz,s1};
Point (5) = { Cx, Cy-R1, Cz,s1};
Circle(1) = {2,1,3};
Circle(2) = {3,1,4};
Circle(3) = {4,1,5};
Circle(4) = {5,1,2};
Line Loop(10) = {1,2,3,4};        //int circ
Plane Surface(30) = {10};
// notes: Layers{n}, n is the number of node in the extrusion direction
ext1[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{30};
 Layers{5}; Recombine;};
ext2[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext1[0]};
ext3[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext2[0]};
ext4[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext3[0]};
ext5[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext4[0]};
ext6[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext5[0]};
ext7[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext6[0]};
ext8[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext7[0]};
ext9[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext8[0]};
ext10[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext9[0]};
ext11[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext10[0]};
ext12[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext11[0]};
ext13[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext12[0]};
ext14[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext13[0]};
ext15[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext14[0]};
ext16[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext15[0]};
ext17[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext16[0]};
ext18[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext17[0]};
ext19[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext18[0]};
ext20[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext19[0]};
ext21[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext20[0]};
ext22[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext21[0]};
ext23[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext22[0]};
ext24[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext23[0]};
ext25[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext24[0]};
ext26[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext25[0]};
ext27[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext26[0]};
ext28[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext27[0]};
ext29[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext28[0]};
ext30[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext29[0]};
ext31[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext30[0]};
ext32[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext31[0]};
ext33[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext32[0]};
ext34[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext33[0]};
ext35[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext34[0]};
ext36[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext35[0]};
ext37[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext36[0]};
ext38[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext37[0]};
ext39[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext38[0]};
ext40[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext39[0]};
ext41[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext40[0]};
ext42[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext41[0]};
ext43[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext42[0]};
ext44[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext43[0]};
ext45[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext44[0]};
ext46[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext45[0]};
ext47[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext46[0]};
ext48[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext47[0]};
ext49[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext48[0]};
ext50[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext49[0]};
ext51[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext50[0]};
ext52[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext51[0]};
ext53[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext52[0]};
ext54[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext53[0]};
ext55[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext54[0]};
ext56[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext55[0]};
ext57[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext56[0]};
ext58[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext57[0]};
ext59[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext58[0]};
ext60[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext59[0]};
ext61[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext60[0]};
ext62[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext61[0]};
ext63[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext62[0]};
ext64[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext63[0]};
ext65[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext64[0]};
ext66[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext65[0]};
ext67[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext66[0]};
ext68[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext67[0]};
ext69[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext68[0]};
ext70[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext69[0]};
ext71[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext70[0]};
ext72[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext71[0]};
ext73[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext72[0]};
ext74[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext73[0]};
ext75[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext74[0]};
ext76[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext75[0]};
ext77[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext76[0]};
ext78[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext77[0]};
ext79[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext78[0]};
ext80[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext79[0]};
ext81[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext80[0]};
ext82[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext81[0]};
ext83[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext82[0]};
ext84[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext83[0]};
ext85[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext84[0]};
ext86[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext85[0]};
ext87[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext86[0]};
ext88[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext87[0]};
ext89[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext88[0]};
ext90[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext89[0]};
ext91[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext90[0]};
ext92[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext91[0]};
ext93[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext92[0]};
ext94[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext93[0]};
ext95[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext94[0]};
ext96[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext95[0]};
ext97[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext96[0]};
ext98[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext97[0]};
ext99[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext98[0]};
ext100[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext99[0]};
ext101[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext100[0]};
ext102[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext101[0]};
ext103[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext102[0]};
ext104[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext103[0]};
ext105[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext104[0]};
ext106[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext105[0]};
ext107[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext106[0]};
ext108[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext107[0]};
ext109[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext108[0]};
ext110[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext109[0]};
ext111[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext110[0]};
ext112[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext111[0]};
ext113[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext112[0]};
ext114[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext113[0]};
ext115[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext114[0]};
ext116[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext115[0]};
ext117[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext116[0]};
ext118[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext117[0]};
ext119[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext118[0]};
ext120[] = Extrude {{0,dh,0}, {0,1,0}, {0,0,0}, Pi/2} {
  Surface{ext119[0]};
ext121[] = Extrude {{0,dh,0}, {0,1,0}, {Cx/2,Cy,Cz}, Pi/2} {
  Surface{ext120[0]};
ext122[] = Extrude {{0,-dh,0}, {0,1,0}, {Cx/2,Cy,Cz}, -Pi/2} {
  Surface{30};
ext123[] = Extrude {{0,0,Cx/2}, {0,0,1}, {Cx/2, Cy+4*30*dh+Cx/2,Cz}, -Pi/2}  {
  Surface{ext121[0]};
 Layers{2*5}; Recombine;};
ext124[] = Extrude {{0,0,-Cx/2}, {0,0,1}, {Cx/2,Cy-dh-Cx/2,Cz}, Pi/2} {
  Surface{ext122[0]};
ext125[] =Extrude {0,10*1.753000E-03, 0} {
  Surface{ext123[0]};
 Layers{4*5}; Recombine;};
ext126[] =Extrude {0,-10*1.753000E-03, 0} {
  Surface{ext124[0]};
Physical Surface("inlet") = {ext125[0]};
Physical Surface("outlet") = {ext126[0]};
Physical Surface("coilInnerSurface")= {ext1[2],ext1[3],ext1[4],ext1[5],ext2[2],ext2[3],ext2[4],ext2[5],ext3[2],ext3[3],ext3[4],ext3[5],ext4[2],ext4[3],ext4[4],ext4[5],ext5[2],ext5[3],ext5[4],ext5[5],
ext6[2],ext6[3],ext6[4],ext6[5],ext7[2],ext7[3],ext7[4],ext7[5],ext8[2],ext8[3],ext8[4],ext8[5],ext9[2],ext9[3],ext9[4],ext9[5],ext10[2],ext10[3],ext10[4],ext10[5],
ext11[2],ext11[3],ext11[4],ext11[5],ext12[2],ext12[3],ext12[4],ext12[5],ext13[2],ext13[3],ext13[4],ext13[5],ext14[2],ext14[3],ext14[4],ext14[5],ext15[2],ext15[3],ext15[4],ext15[5],
ext16[2],ext16[3],ext16[4],ext16[5],ext17[2],ext17[3],ext17[4],ext17[5],ext18[2],ext18[3],ext18[4],ext18[5],ext19[2],ext19[3],ext19[4],ext19[5],ext20[2],ext20[3],ext20[4],ext20[5],
ext21[2],ext21[3],ext21[4],ext21[5],ext22[2],ext22[3],ext22[4],ext22[5],ext23[2],ext23[3],ext23[4],ext23[5],ext24[2],ext24[3],ext24[4],ext24[5],ext25[2],ext25[3],ext25[4],ext25[5],
ext26[2],ext26[3],ext26[4],ext26[5],ext27[2],ext27[3],ext27[4],ext27[5],ext28[2],ext28[3],ext28[4],ext28[5],ext29[2],ext29[3],ext29[4],ext29[5],ext30[2],ext30[3],ext30[4],ext30[5],
ext31[2],ext31[3],ext31[4],ext31[5],ext32[2],ext32[3],ext32[4],ext32[5],ext33[2],ext33[3],ext33[4],ext33[5],ext34[2],ext34[3],ext34[4],ext34[5],ext35[2],ext35[3],ext35[4],ext35[5],
ext36[2],ext36[3],ext36[4],ext36[5],ext37[2],ext37[3],ext37[4],ext37[5],ext38[2],ext38[3],ext38[4],ext38[5],ext39[2],ext39[3],ext39[4],ext39[5],ext40[2],ext40[3],ext40[4],ext40[5],
ext41[2],ext41[3],ext41[4],ext41[5],ext42[2],ext42[3],ext42[4],ext42[5],ext43[2],ext43[3],ext43[4],ext43[5],ext44[2],ext44[3],ext44[4],ext44[5],ext45[2],ext45[3],ext45[4],ext45[5],
ext46[2],ext46[3],ext46[4],ext46[5],ext47[2],ext47[3],ext47[4],ext47[5],ext48[2],ext48[3],ext48[4],ext48[5],ext49[2],ext49[3],ext49[4],ext49[5],ext50[2],ext50[3],ext50[4],ext50[5],
ext51[2],ext51[3],ext51[4],ext51[5],ext52[2],ext52[3],ext52[4],ext52[5],ext53[2],ext53[3],ext53[4],ext53[5],ext54[2],ext54[3],ext54[4],ext54[5],ext55[2],ext55[3],ext55[4],ext55[5],
ext56[2],ext56[3],ext56[4],ext56[5],ext57[2],ext57[3],ext57[4],ext57[5],ext58[2],ext58[3],ext58[4],ext58[5],ext59[2],ext59[3],ext59[4],ext59[5],ext60[2],ext60[3],ext60[4],ext60[5],
ext61[2],ext61[3],ext61[4],ext61[5],ext62[2],ext62[3],ext62[4],ext62[5],ext63[2],ext63[3],ext63[4],ext63[5],ext64[2],ext64[3],ext64[4],ext64[5],ext65[2],ext65[3],ext65[4],ext65[5],
ext66[2],ext66[3],ext66[4],ext66[5],ext67[2],ext67[3],ext67[4],ext67[5],ext68[2],ext68[3],ext68[4],ext68[5],ext69[2],ext69[3],ext69[4],ext69[5],ext70[2],ext70[3],ext70[4],ext70[5],
ext71[2],ext71[3],ext71[4],ext71[5],ext72[2],ext72[3],ext72[4],ext72[5],ext73[2],ext73[3],ext73[4],ext73[5],ext74[2],ext74[3],ext74[4],ext74[5],ext75[2],ext75[3],ext75[4],ext75[5],
ext76[2],ext76[3],ext76[4],ext76[5],ext77[2],ext77[3],ext77[4],ext77[5],ext78[2],ext78[3],ext78[4],ext78[5],ext79[2],ext79[3],ext79[4],ext79[5],ext80[2],ext80[3],ext80[4],ext80[5],
ext81[2],ext81[3],ext81[4],ext81[5],ext82[2],ext82[3],ext82[4],ext82[5],ext83[2],ext83[3],ext83[4],ext83[5],ext84[2],ext84[3],ext84[4],ext84[5],ext85[2],ext85[3],ext85[4],ext85[5],
ext86[2],ext86[3],ext86[4],ext86[5],ext87[2],ext87[3],ext87[4],ext87[5],ext88[2],ext88[3],ext88[4],ext88[5],ext89[2],ext89[3],ext89[4],ext89[5],ext90[2],ext90[3],ext90[4],ext90[5],
ext91[2],ext91[3],ext91[4],ext91[5],ext92[2],ext92[3],ext92[4],ext92[5],ext93[2],ext93[3],ext93[4],ext93[5],ext94[2],ext94[3],ext94[4],ext94[5],ext95[2],ext95[3],ext95[4],ext95[5],
ext96[2],ext96[3],ext96[4],ext96[5],ext97[2],ext97[3],ext97[4],ext97[5],ext98[2],ext98[3],ext98[4],ext98[5],ext99[2],ext99[3],ext99[4],ext99[5],ext100[2],ext100[3],ext100[4],ext100[5],
ext101[2],ext101[3],ext101[4],ext101[5],ext102[2],ext102[3],ext102[4],ext102[5],ext103[2],ext103[3],ext103[4],ext103[5],ext104[2],ext104[3],ext104[4],ext104[5],ext105[2],ext105[3],ext105[4],ext105[5],
ext106[2],ext106[3],ext106[4],ext106[5],ext107[2],ext107[3],ext107[4],ext107[5],ext108[2],ext108[3],ext108[4],ext108[5],ext109[2],ext109[3],ext109[4],ext109[5],ext110[2],ext110[3],ext110[4],ext110[5],
ext111[2],ext111[3],ext111[4],ext111[5],ext112[2],ext112[3],ext112[4],ext112[5],ext113[2],ext113[3],ext113[4],ext113[5],ext114[2],ext114[3],ext114[4],ext114[5],ext115[2],ext115[3],ext115[4],ext115[5],
ext116[2],ext116[3],ext116[4],ext116[5],ext117[2],ext117[3],ext117[4],ext117[5],ext118[2],ext118[3],ext118[4],ext118[5],ext119[2],ext119[3],ext119[4],ext119[5],ext120[2],ext120[3],ext120[4],ext120[5],
ext121[2],ext121[3],ext121[4],ext121[5],ext122[2],ext122[3],ext122[4],ext122[5],ext123[2],ext123[3],ext123[4],ext123[5],ext124[2],ext124[3],ext124[4],ext124[5],ext125[2],ext125[3],ext125[4],ext125[5],
ext126[2],ext126[3],ext126[4],ext126[5]};
Physical Volume("coil")= {ext1[],ext2[],ext3[],ext4[],ext5[],ext6[],ext7[],ext8[],ext9[],ext10[],
ext11[],ext12[],ext13[],ext14[],ext15[],ext16[],ext17[],ext18[],ext19[],ext20[],
ext21[],ext22[],ext23[],ext24[],ext25[],ext26[],ext27[],ext28[],ext29[],ext30[],
ext31[],ext32[],ext33[],ext34[],ext35[],ext36[],ext37[],ext38[],ext39[],ext40[],
ext41[],ext42[],ext43[],ext44[],ext45[],ext46[],ext47[],ext48[],ext49[],ext50[],
ext51[],ext52[],ext53[],ext54[],ext55[],ext56[],ext57[],ext58[],ext59[],ext60[],
ext61[],ext62[],ext63[],ext64[],ext65[],ext66[],ext67[],ext68[],ext69[],ext70[],
ext71[],ext72[],ext73[],ext74[],ext75[],ext76[],ext77[],ext78[],ext79[],ext80[],
ext81[],ext82[],ext83[],ext84[],ext85[],ext86[],ext87[],ext88[],ext89[],ext90[],
ext91[],ext92[],ext93[],ext94[],ext95[],ext96[],ext97[],ext98[],ext99[],ext100[],
ext101[],ext102[],ext103[],ext104[],ext105[],ext106[],ext107[],ext108[],ext109[],ext110[],
ext111[],ext112[],ext113[],ext114[],ext115[],ext116[],ext117[],ext118[],ext119[],ext120[],
ext121[],ext122[],ext123[],ext124[],ext125[],ext126[]};
Jinbiao
JinBiao is offline   Reply With Quote
Old   August 31, 2010, 02:55
Jinbiao Xiong
3 errors when I checkMesh.
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
    faces:            2041712
    internal faces:   1924688
    cells:            793280
    boundary patches: 4
    point zones:      0
    face zones:       0
    cell zones:       1
Overall number of cells of each type:
    hexahedra:     0
    prisms:        793280
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
Checking topology...
    Boundary definition OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
    Patch               Faces    Points   Surface topology
    inlet               592      325      ok (non-closed singly connected)
    outlet              592      325      ok (non-closed singly connected)
    coilInnerSurface    68680    75096    ok (non-closed singly connected)
    defaultFaces        47160    36727    multiply connected (shared edge)
  <<Writing 19438 conflicting points to set nonManifoldPoints
Checking geometry...
    Overall domain bounding box (-0.0082265 -0.0218 -0.0082265) (0.0082265 0.092605 0.0082265)
    Mesh (non-empty, non-wedge) directions (1 1 1)
    Mesh (non-empty) directions (1 1 1)
    Boundary openness (-2.89129e-09 -1.27362e-08 2.17817e-09) OK.
 ***Open cells found, max cell openness: 0.633005, number of open cells 9126
  <<Writing 9126 non closed cells to set nonClosedCells
  <<Writing 2400 cells with high aspect ratio to set highAspectRatioCells
    Minumum face area = 1.53247e-12. Maximum face area = 2.29522e-07.  Face area magnitudes OK.
    Min volume = 1.66667e-300. Max volume = 1.03492e-11.  Total volume = 3.4394e-06.  Cell volumes OK.
    Mesh non-orthogonality Max: 176.879 average: 14.7507
   *Number of severely non-orthogonal faces: 2400.
 ***Number of non-orthogonality errors: 5409.
  <<Writing 7809 non-orthogonal faces to set nonOrthoFaces
 ***Error in face pyramids: 28094 faces are incorrectly oriented.
  <<Writing 23285 faces with incorrect orientation to set wrongOrientedFaces
    Max skewness = 3.76412 OK.
Failed 3 mesh checks.
End
Jinbiao
Old   August 31, 2010, 05:51
Jinbiao Xiong
The problem has been solved. The reason was that I clicked the "refine" button when building the mesh.
Jinbiao
[Gmsh] gMsh instead of blockMesh for base mesh, then snappyHexMesh sazabi2001 OpenFOAM Meshing & Mesh Conversion 0 February 23, 2017 13:00
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 10:03
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
[Gmsh] gmshToFoam problem: not the same mesh in Gmsh vs. paraview zhernadi OpenFOAM Meshing & Mesh Conversion 8 July 7, 2011 03:28
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 11:56
