July 16, 2010, 11:13 |
Embedded blocks
Robertas N.
Rep Power: 17 |
Hi all,
I need to define a hex block inside a rectangular computational domain, which is basically a block also. Is there any possibility to define a smaller block inside a larger block, like e.g. this: Code:
vertices ( (0 0 0) // 00 (15 0 0) // 01 (15 6 0) // 02 (0 6 0) // 03 (0 0 6) // 04 (15 0 6) // 05 (15 6 6) // 06 (0 6 6) // 07 // ************** (5 1 2) // 08 (12 1 2) // 09 (12 4 2) // 10 (5 4 2) // 11 (5 1 5) // 12 (12 1 5) // 13 (12 4 5) // 14 (5 4 5) // 15 ); blocks ( hex (0 1 2 3 4 5 6 7) (30 12 12) simpleGrading (1 1 1) hex (8 9 10 11 12 13 14 15) block_porosity (14 6 6) simpleGrading (1 1 1) ); I need the setup of the above type to simulate flows in porous media because the standard way to define porous zones is to define the blocks and associate the porous zones with the appropriate blocks. How to implement the setup where the porous media only partially fills the overall domain? Define multiple blocks that tile the 3D domain? |
[Commercial meshers] fluent3DMeshToFoam | bego | OpenFOAM Meshing & Mesh Conversion | 31 | August 16, 2023 09:04 |
[Commercial meshers] COnvert FLuent MEsh to openfoam with interface | manuc | OpenFOAM Meshing & Mesh Conversion | 1 | July 25, 2017 03:13 |
[Commercial meshers] converting Fluent mesh to openfoam standard mesh | deepesh | OpenFOAM Meshing & Mesh Conversion | 31 | March 29, 2017 05:59 |
dsmcInitialise - dsmcFoam | archymedes | OpenFOAM Pre-Processing | 94 | July 15, 2016 16:14 |
[Other] How to create an MRF zone ? | aminem | OpenFOAM Meshing & Mesh Conversion | 2 | December 8, 2014 10:45 |
