[blockMesh] Grid generation cross flow over circular cylinder |
July 7, 2010, 08:02 |
Rep Power: 16 |
Hi everyone,
i just started to familiarize myself with OpenFoam. I want to simulate cross flow over a circular cylinder for relatively low Re numbers (100-300). I was thinking about using a block structured mesh consisting of 3 blocks. An O-type mesh in the region of the cylinder wall, a C-type mesh for the region in front of the cylinder and the wake region, and a coarse mesh for the rest of the flow field. What do you think of this grid structure? Are you proposing another grid structure? Has anyone got an example of a blockMeshDict file for a similar problem? Many thanks in advance. |
Reference area for 2.5D circular cylinder flow | siw | Main CFD Forum | 0 | February 23, 2019 07:00 |
Problem with grid convergence for turbulent flow around cylinder | aakie | OpenFOAM Running, Solving & CFD | 3 | November 13, 2018 04:39 |
Problem with wake pressure for unsteady flow around circular cylinder | Bazinga | OpenFOAM | 2 | August 27, 2018 07:13 |
2D flow around a circular cylinder case with interFoam solver | shuoxue | OpenFOAM Running, Solving & CFD | 0 | August 31, 2013 05:04 |
Particle deposition on circular cylinder in turbulent flow | Julian K. | CFX | 1 | October 3, 2011 17:51 |
