[blockMesh] Problems in creating a wedge type mesh
Like Tree2Likes
Old   March 6, 2015, 09:25
Alexander Bartel
alexB is on a distinguished road
Hi Gareth,
perhaps a bit late, but (7 8 17 16) is no proper defined face.
7 and 16, and 8 and 17 define the same points in your blockMesh.
greetings
Alex
alexB is offline   Reply With Quote
Old   May 13, 2015, 07:28
Adkar
adkar is on a distinguished road
If you want 2d mesh, set the same points again like follows.
vertices
(0 0 0)
(1 0 0)
(1 1 0)
(0 1 0)
(0 0 0)
(1 0 0)
(1 1 0)
(0 1 0)
adkar is offline   Reply With Quote
Old   May 14, 2015, 06:10
Alexander Bartel
Hi Adkar,
I don't know where you are referring to...
But your idea won't work.
If you want to set up a two-dimensional case you still have to make your mesh three-dimensional, but define the front and back boundaries as empty boundaries.
Just have a look at the cavity tutorial /incompressible/icofoam/cavity
regards
Alex
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
Old   October 16, 2015, 04:28
Adkar
vertices
(0 0 0)
(1 0 0)
(1 1 0)
(0 1 0)
(0 0 0)
(1 0 0)
(1 1 0)
(0 1 0)
Yeah..i was wrong. Sorry for the inconvinence.
Old   November 2, 2015, 10:58
Default Negative pyramid volume
  #25
Vignesh
vigneshTG is on a distinguished road
Hello everyone,
I made my own axi-symmetric mesh in 2D following the steps listed in this page. I get these warnings ...
--> FOAM Warning :
    From function cellModel::mag(const labelList&, const pointField&)
    in file meshes/meshShapes/cellModel/cellModel.C at line 128
    zero or negative pyramid volume: -1.13485e-07 for face 1
--> FOAM Warning :
    zero or negative pyramid volume: -5.67424e-08 for face 2
--> FOAM Warning :
    zero or negative pyramid volume: -5.67424e-08 for face 3
--> FOAM Warning :
    zero or negative pyramid volume: -5.67424e-08 for face 4
--> FOAM Warning :
    zero or negative pyramid volume: -5.67424e-08 for face 5
--> FOAM Warning :
    From function blockMesh::createTopology(IOdictionary&)
    in file blockMesh/blockMeshTopology.C at line 255
    negative volume block : 0, probably defined inside-out
Can somebody tell me what i am doing wrong ??
here is the blockMeshDict file
|  \\    /   O peration     | Version:  2.3.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 1.0;
// a- 0.024976
//b- 0.0010905
vertices
    (0 0 0)                 // pt_0
    (0.024976 0 0.0010905)         // pt_1
    (0.024976 0.0125 0.0010905)     // pt_2
    (0 0.0125 0)                 // pt_3
    (0.024976 0 -0.0010905)           // pt_4
    (0.024976 0.0125 -0.0010905)       // pt_5
blocks
    hex (0 4 1 0 3 5 2 3) (20 1 20) simpleGrading (1 1 1)
//    hex (0 1 4 0 3 2 5 3) (20 20 1) simpleGrading (1 1 1)
edges
boundary
     front
           type wedge;
           faces
               (0 1 2 3)
     back
           type wedge;
           faces
               (0 3 5 4)
     right
           type wall;
           faces
               (1 4 5 2)
    bottom
           type wall;
           faces
               (0 4 1 0)
     top
           type wall;
           faces
               (3 5 2 3)
     axis
           type empty;
           faces
               (0 3 3 0)
mergePatchPairs
Thanks and Regards
Vignesh
vigneshTG is offline   Reply With Quote
Old   November 2, 2015, 11:56
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
In general negative volume of cells is a result of wrong vertex numbering. If you change
to
hex (3 5 2 3 0 4 1 0) (20 1 20) simpleGrading (1 1 1)
Errors disappear.
alexeym is offline   Reply With Quote
Old   November 3, 2015, 03:06
Vignesh
Originally Posted by alexeym View Post
to
Errors disappear.
Thank you alexeym !!
Thanks and Regards
Vignesh
Old   November 3, 2015, 12:27
Default Automating wedge points using m4 programming
  #28
usv001 is on a distinguished road
Hello everyone,
I have written a very simple script in m4 to create the points of the wedge:
divert(-1)
define([wedge],
[ifelse(calc(([$2]==0)),1,
[($1 0 0)],
[($1 calc($2*cos(2.5*pi/180)) calc($2*sin(2.5*pi/180)))
   ($1 calc($2*cos(-2.5*pi/180)) calc($2*sin(-2.5*pi/180)))])])dnl
divert
If you input the points in the x,y plane, it will return two points revolved 2.5deg on either side about x-axis. So,
wedge(1,2) -> two points
(1 1.99809837241304 0.0871945764388748)
(1 1.99809837241304 -0.0871945764388748)
wedge(1,0) -> only one point returned if point is on x-axis
(1 0 0)
It's a little primitive but works for me.
sourav90 likes this.
usv001 is offline   Reply With Quote
Old   August 3, 2019, 08:59
Smile
  #29
Sourav Mandal
sourav90 is on a distinguished road
Thanks https://www.cfd-online.com/Forums/members/trt.html, very much for sharing your code! Was pulling my hair to get a simple example go wedge geometry until I found this...
sourav90 is offline   Reply With Quote
[blockMesh] 3-D Mesh in a cylinder Nikunj.R OpenFOAM Meshing & Mesh Conversion 32 July 9, 2023 14:22
[Commercial meshers] Problems with ANSYS mesh conversion tdog OpenFOAM Meshing & Mesh Conversion 1 March 31, 2016 18:36
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
Problem with geometry - concentric cylinders Rhoddwen OpenFOAM Running, Solving & CFD 0 December 15, 2014 10:22
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
