[Gmsh] Gmsh pipes on a cylinder
Old   April 9, 2010, 16:37
Default Gmsh pipes on a cylinder
john Welker
Cheme is on a distinguished road
I'm trying to use Gmsh construct a simple geometry consisting of a large cylinder with a few pipes entering and exiting the curved surface of the cylinder. This is very simple to do using Gambit but Does gmsh have a way to make points or draw circles etc on the curved surface of the cylinder. It also seems to lack tha ability to split volumes or too calculate the intersections of volumes.
Cheme is offline   Reply With Quote
Old   May 19, 2010, 07:27
Benedikt Goeppner
bgoeppner is on a distinguished road
Hi John,
I'm sorry that I can't help you there. However, I'm also interested in the solution for this kind of problem as I had the same situation some months ago...
I finally used netgen but it'd be still nice to know how I could have done this with gmsh...
So if you find an answer I'd appreciate if you post it here...
Greetings,
Ben
bgoeppner is offline   Reply With Quote
gmsh cylinder
[Gmsh] 3D Free surface flow past circular cylinder meshing using GMSH arieljeds OpenFOAM Meshing & Mesh Conversion 7 January 14, 2017 13:57
[Gmsh] Cylinder from Gmsh to OpenFoam satkinson OpenFOAM Meshing & Mesh Conversion 0 September 21, 2015 08:49
[Gmsh] Gmsh to Openfoam cylinder satkinson OpenFOAM Meshing & Mesh Conversion 0 September 17, 2015 13:31
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 11:56
