November 30, 2010, 23:03 |
fluent3DMeshToFoam
#21 |
NAVEEN.K.M
Rep Power: 17 |
hi grandgo
Just go to the file where your case is located, and type paraFoam and switch off all the vol Field status and accept it..... regards, NAVEEN |
December 1, 2010, 10:59 |
#22 |
Rep Power: 16 |
thanks naveen!
December 3, 2010, 11:06 |
#23 |
Jason G.
Rep Power: 17 |
December 6, 2010, 07:10 |
#24 |
Rep Power: 16 |
April 13, 2011, 15:26 |
converting .msh fluentmeshtofoam
#25 | |
Marta
Rep Power: 15 |
Hi farghaim,
I am new in OpenFOAM and I´m trying to convert a .msh from FLUENT to OpenFOAM. I´m using OF 1.7.1. I got the same error message you posted in May 2010. Did you find any solution to this problem? I paste you my message in OF hemodynamics@marioc-PowerEdge-R300:~/OpenFOAM/hemodynamics-1.7.1/run/marta/poiseuille_mesh$ fluentMeshToFoam ascii.msh /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.x | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.7.x-3776603e4c6c Exec : fluentMeshToFoam ascii.msh Date : Apr 11 2011 Time : 22:45:41 Host : marioc-PowerEdge-R300 PID : 13356 Case : /home/hemodynamics/OpenFOAM/hemodynamics-1.7.1/run/marta/poiseuille_mesh nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time number of faces: 1643 Number of points: 203 Reading uniform faces Reading points FINISHED LEXING #0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam171/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigSegv::sigSegvHandler(int) in "/opt/openfoam171/lib/linux64GccDPOpt/libOpenFOAM.so" #2 in "/lib/libc.so.6" #3 in "/opt/openfoam171/applications/bin/linux64GccDPOpt/fluentMeshToFoam" #4 __libc_start_main in "/lib/libc.so.6" #5 in "/opt/openfoam171/applications/bin/linux64GccDPOpt/fluentMeshToFoam" Violación de segmento hemodynamics@marioc-PowerEdge-R300:~/OpenFOAM/hemodynamics-1.7.1/run/marta/poiseuille_mesh$ Quote:
April 14, 2011, 03:18 |
#26 |
Matthias Voß
Rep Power: 20 |
Did you also tried fluent3DMeshtoFoam ?
April 14, 2011, 08:02 |
#27 |
Marta
Rep Power: 15 |
Thank you Matthias for answering my message.
My mesh is a 2D bifurcation, that is why I am using fluentMeshToFoam. Does fluent3DMeshToFoam work better than fluentMeshToFoam? Do you know what can be the source of my errors? I don´t understand what they mean or how to solve them! Thanks, Marta. |
May 29, 2013, 13:08 |
Remember to save mesh as ASCII!
#28 |
Simon
Rep Power: 13 |
I had the same error message as OP. The problem was that the mesh exported by Fluent was in binary format, not ASCII as is required by fluentMeshToFoam. To export as ASCII in ANSYS Meshing, do Tools > Options > Meshing > Export and you will see the option.
April 16, 2018, 09:22 |
#29 |
October 7, 2019, 04:15 |
Embedded blocks in comment or unkown
#30 |
Rosario Arnau
Rep Power: 9 |
Hi everyone,
In my case the message "Embedded blocks in comment or unkown" is returned so many times: Code:
@Embedded blocks in comment or unknown:Ҧ \@▒?Embedded blocks in comment or unknown:▒ @ܒ|Embedded blocks in comment or unknown:▒ xterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256colorxterm-256color Thanks, |
January 8, 2020, 06:41 |
#31 |
Przemek
Rep Power: 16 |
Hi
I got similar problem. I opened msh file in ICEM, saved as fluent mesh there and now it works.
best regards pblasiak |
August 16, 2023, 09:04 |
#32 | |
David Kinast
Rep Power: 9 |
I had the same problem. Saving in ASCII-format fixed it! |
periodic (cyclic) boundary - fluent3DMeshToFoam | cyln | OpenFOAM | 1 | October 17, 2017 02:59 |
[Commercial meshers] fluent3DMeshToFoam conversion problem | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 14 | March 12, 2014 05:16 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
[Commercial meshers] fluentMeshToFoam instead of fluent3DMeshToFoam | sasanghomi | OpenFOAM Meshing & Mesh Conversion | 2 | March 29, 2013 07:58 |
OpenFOAM command from inside MATLAB | sega | OpenFOAM Post-Processing | 18 | September 25, 2012 07:35 |
