January 2, 2018, 00:43 |
#41 | |
Rep Power: 8 |
February 10, 2018, 06:32 |
problem in runnung unv mesh in openfoam
#42 |
Rep Power: 9 |
Hello Foamers,
I am making a cubical Bounding Box in unv mesh format for my case file.when i run it in openfoam it works fine. but when i check it using paraview, it shows me this error:: "Mesh Contains no cells" can anybody help me to sort out this problem??? |
March 4, 2022, 21:41 |
#43 |
Outside North America
Rep Power: 5 |
Hi, I have a problem with grid conversion. When I tried to convert the Unv grid file exported from Salome to a format supported by OpenFoam, it got the following error. Do you know why?
Thank you! thk@LAPTOP-04QGRRSQ:~/run/cavity$ ls 0 constant logs pipe.unv system thk@LAPTOP-04QGRRSQ:~/run/cavity$ ideasUnvToFoam pipe.unv /*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 7 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 7-3bcbaf946ae9 Exec : ideasUnvToFoam pipe.unv Date : Mar 05 2022 Time : 09:31:20 Host : "LAPTOP-04QGRRSQ" PID : 677 I/O : uncollated Case : /home/thk/run/cavity nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM FATAL ERROR: Cannot open file "pipe.unv" From function int main(int, char**) in file ideasUnvToFoam.C at line 679. FOAM exiting |
[Salome] Problems for creating mesh in salome to OPENFOAM | bye bye my blue | OpenFOAM Meshing & Mesh Conversion | 8 | December 5, 2023 01:57 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
[Commercial meshers] Mesh conversion .gtm to OpenFOAM | ansab | OpenFOAM Meshing & Mesh Conversion | 2 | December 6, 2016 14:48 |
[Commercial meshers] Problems with ANSYS mesh conversion | tdog | OpenFOAM Meshing & Mesh Conversion | 1 | March 31, 2016 18:36 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
