March 11, 2010, 05:30 |
Problem with mergeMeshes
Bernd Stöver
Rep Power: 17 |
i would like to do a rotor/stator calculation. Thus i created two meshes, converted them with fluent3dmeshtoFoam, checked the meshs and renumbered them. Now i wanted to merge the meshes for the calculation. This fails. Here is the output: Code:
Build : 1.6-f802ff2d6c5a Exec : mergeMeshes . ../channel3/ . ../Rotor5 Date : Mar 10 2010 ... PID : 4782 Case : /home/bstoeve/OpenFOAM/Rotor/all2 nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). ... Master: "." "../channel3/" mash to add: "." "../Rotor5/" Create Times Reading master mesh for time = 0 Create mesh Reading mesh to add for time = 0 Create mesh Writing combined mesh to 1 patch names: ... Copying old patches Adding new patches. Illegal zoneID 1 for face 21733698#0 Foam::error::printStack(Foam::Ostream&) in "/home/bstoeve/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/home/bstoeve/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #2 Foam::polyTopoChange::resetZones(Foam::polyMesh const&, Foam::polyMesh&, Foam::List<Foam::List<int> >&, Foam::List<Foam::List<int> >&, Foam::List<Foam::List<int> >&) const in "/home/bstoeve/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libdynamicMesh.so" #3 Foam::polyTopoChange::changeMesh(Foam::polyMesh&, bool, bool, bool, bool) in "/home/bstoeve/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libdynamicMesh.so" #4 Foam::mergePolyMesh::merge() in "/home/bstoeve/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/mergeMeshes" #5 main in "/home/bstoeve/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/mergeMeshes" #6 __libc_start_main in "/lib/libc.so.6" #7 _start at /build/buildd/eglibc-2.10.1/csu/../sysdeps/x86_64/elf/start.S:116 From function resetZones(const polyMesh&, polyMesh&, labelListList&labelListList&, labelListList&) in file polyTopoChange/polyTopoChange/polyTopoChange.C at line 1575. FOAM aborting Code:
faceZone from Fluent indices: 0 to: 21733697 type: interior patch 0 from Fluent indices: 21733698 to: 21881973 type: wall patch 1 from Fluent indices: 21881974 to: 21889726 type: wall patch 2 from Fluent indices: 21889727 to: 21947236 type: wall patch 3 from Fluent indices: 21947237 to: 21969365 type: wall patch 4 from Fluent indices: 21969366 to: 21988347 type: wall patch 5 from Fluent indices: 21988348 to: 22007989 type: wall patch 6 from Fluent indices: 22007990 to: 22028676 type: wall patch 7 from Fluent indices: 22028677 to: 22049363 type: wall |
March 14, 2010, 04:09 |
O.k. solved this
Bernd Stöver
Rep Power: 17 |
well, i 'solved' the problem by not using fluent3DMeshToFoam. It doesn't work (at least in version 1.6). Using fluentMeshToFoam works. |
BuoyantBoussinesqSimpleFoam_Facing problem | Mondal131211 | OpenFOAM Running, Solving & CFD | 1 | April 10, 2019 20:41 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 05:43 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 07:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 20:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 15:52 |
