[blockMesh] blockmesh arc, no curves, no arc, only straight lines
Old   March 8, 2010, 11:56
Default blockmesh arc, no curves, no arc, only straight lines
heavy_user is on a distinguished road
HI Folks,
i have been trying to create a slice of a cylinder (like a peace of cake).
But blockmesh is not making curved lines for me.
I tried to figure why, but i am stuck.
I made a really simple case, which is symmetric to the y-axis.
On the -y side he is making an arc, on the +y side not...and i dont know why..(attached picture, it is supposed to be half a circle)
Did I overlook something simple??
|  \\    /   O peration     | Version:  1.6                                   |
|   \\  /    A nd           | Web:      http://www.OpenFOAM.org               |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 1;
vertices
    (0     0    0)
    (1 0 0)
    (0 1 0)
    (-1  0 0)
    (0    0    2)
    (1 0 2)
    (0 1  2)
    (-1 0  2)
edges
           //(1/sqrt (2) 1/sqrt (2) 0 )
arc 1 2 (0.70710678 0.70710678 0)
arc 2 3 (-0.70710678 0.70710678 0)
arc 5 6 (0.70710678 0.70710678 2)
arc 6 7 (-0.70710678 0.70710678 2)
blocks
    hex (0 1 2 3 4 5 6 7)      (10 1 60) simpleGrading (3 1 3)
patches
    patch inlet
        (0 3 2 1)
    wall sidewall
       (2 6 5 1)
       (3 7 6 2)
    wall wedge
    (0 1 5 4)
    (4 7 3 0)
    patch outlet
    (4 7 6 5)
mergePatchPairs
heavy_user is offline   Reply With Quote
Old   March 22, 2010, 06:58
Paul Garlick
pg22 is on a distinguished road
I think that the block definition is wrong here. There is only one block which would lead to highly skewed cells.
It would be better to use an O-type grid. The semi-circular region would be split into four sub-regions. In this layout there would be a central rectangular region surrounded by three outer regions. The outer regions would have curved outer edges to fit the semi-circular geometry.
pg22 is offline   Reply With Quote
Old   July 27, 2013, 06:11
Default Draw the geometry in blockmesh
psk
david
psk is an unknown quantity at this point
Good Day Folks,
I am trying to draw my wing geometry inside blockMesh [ ie. wing is locate inside the domain] for that i create domain,
Domain (Rectangular )
(0 0 0) // vertex 0
(100 0 0) // vertex 1
(100 0 25) // vertex 2
(0 100 0) // vertex 3
(0 100 0) // vertex 4
(100 100 0) // vertex 5
(100 100 25) // vertex 6
(0 100 25) // vertex 7
blocks
hex (0 1 2 3 4 5 6 7) (20 20 1) simpleGrading (1 1 1)
wing Geometry coordinates
points[1] = point(11.03188, 3.534115, 6.404323);
points[2] = point(3.190682, 4.892467, 5.764356);
points[3] = point(9.559749, -5.47123, 2.317475);
__________________________________________________ ___________________
I took example of blockMesh from potentialFoam cylinder tutorial, kindly help me how I can built wing inside the domain using blockMeshDict.kindly see my attached wing & blockMeshDict for your kind perusal.while running blockmesh I got erroe like this,
toshiba@ubuntu:~/OpenFOAM/toshiba-2.1.0/run/openfoam210/tutorials/basic/potentialFoam/testcylinder/cylinder$ blockMesh
| \\ / O peration | Version: 2.1.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
Build : 2.1.0-0bc225064152
Exec : blockMesh
Date : Jul 27 2013
Time : 15:07:51
Host : "ubuntu"
PID : 4111
Case : /home/toshiba/OpenFOAM/toshiba-2.1.0/run/openfoam210/tutorials/basic/potentialFoam/testcylinder/cylinder
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Creating block mesh from
"/home/toshiba/OpenFOAM/toshiba-2.1.0/run/openfoam210/tutorials/basic/potentialFoam/testcylinder/cylinder/constant/polyMesh/blockMeshDict"
Using #codeStream at line 19 in file "/home/toshiba/OpenFOAM/toshiba-2.1.0/run/openfoam210/tutorials/basic/potentialFoam/testcylinder/cylinder/constant/polyMesh/blockMeshDict"
Using #codeStream with "/home/toshiba/OpenFOAM/toshiba-2.1.0/run/openfoam210/tutorials/basic/potentialFoam/testcylinder/cylinder/dynamicCode/platforms/linuxGccDPOpt/lib/libcodeStream_257d30184e57a5c9c2f645de53bc3f5b42c8 fb53.so"
Creating new library in "dynamicCode/_257d30184e57a5c9c2f645de53bc3f5b42c8fb53/platforms/linuxGccDPOpt/lib/libcodeStream_257d30184e57a5c9c2f645de53bc3f5b42c8 fb53.so"
Invoking "wmake -s libso /home/toshiba/OpenFOAM/toshiba-2.1.0/run/openfoam210/tutorials/basic/potentialFoam/testcylinder/cylinder/dynamicCode/_257d30184e57a5c9c2f645de53bc3f5b42c8fb53"
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file codeStreamTemplate.C
/home/toshiba/OpenFOAM/toshiba-2.1.0/run/openfoam210/tutorials/basic/potentialFoam/testcylinder/cylinder/constant/polyMesh/blockMeshDict::#codeStream: In function ‘void Foam::codeStream_257d30184e57a5c9c2f645de53bc3f5b4 2c8fb53(Foam::Ostream&, const Foam::dictionary&)’:
/home/toshiba/OpenFOAM/toshiba-2.1.0/run/openfoam210/tutorials/basic/potentialFoam/testcylinder/cylinder/constant/polyMesh/blockMeshDict::#codeStream:34:8: error: ‘line’ was not declared in this scope
/home/toshiba/OpenFOAM/toshiba-2.1.0/run/openfoam210/tutorials/basic/potentialFoam/testcylinder/cylinder/constant/polyMesh/blockMeshDict::#codeStream:36:6: error: ‘lines’ was not declared in this scope
make: *** [Make/linuxGccDPOpt/codeStreamTemplate.o] Error 1
--> FOAM FATAL IO ERROR:
Failed wmake "dynamicCode/_257d30184e57a5c9c2f645de53bc3f5b42c8fb53/platforms/linuxGccDPOpt/lib/libcodeStream_257d30184e57a5c9c2f645de53bc3f5b42c8 fb53.so"
file: /home/toshiba/OpenFOAM/toshiba-2.1.0/run/openfoam210/tutorials/basic/potentialFoam/testcylinder/cylinder/constant/polyMesh/blockMeshDict from line 17 to line 17.
From function functionEntries::codeStream::execute(..)
in file db/dictionary/functionEntries/codeStream/codeStream.C at line 195.
FOAM exiting
Million Thanks,
David
"Small Dream is a Crime"
psk is offline   Reply With Quote
Old   January 20, 2017, 17:49
Default your mesh
Manuel Fermin Fonseca
manuelffonseca is on a distinguished road
dude, you have this
edges
but the arc have to have a point between vertice 1 and 2, that mean you need a pont that satisfy the circunference equacion, 2ndf you have to reconfigurate the vertices to a real coordinates, because i see between the Parentheses (), looks like the cube coords as sown below
vertices
(0 0 0)
(1 0 0)
(0 1 0)
(-1 0 0)
(0 0 2)
(1 0 2)
(0 1 2)
(-1 0 2)
i think the real vertices are
(0 0 0)
(1 0 0)
(0 0 z)
(1 0 z)
(0.70710678 0.70710678 z)
whre z can to be a small number
can i to help you
Best regards
Originally Posted by heavy_user View Post
HI Folks,
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
convertToMeters 1;
vertices
    (0     0    0)
    (1 0 0)
    (0 1 0)
    (-1  0 0)
    (0    0    2)
    (1 0 2)
    (0 1  2)
    (-1 0  2)
edges
blocks
patches
    patch inlet
        (0 3 2 1)
    wall sidewall
       (2 6 5 1)
       (3 7 6 2)
    wall wedge
    (0 1 5 4)
    (4 7 3 0)
    patch outlet
    (4 7 6 5)
mergePatchPairs
manuelffonseca is offline   Reply With Quote
Old   January 20, 2017, 22:50
using this
| \\ / O peration | Version: 2.1 |
FoamFile
version 2.0;
format ascii;
class dictionary;
convertToMeters 0.1;
vertices
(0 0 0)
(1 0 0)
(0 0 0.1)
(1 0 0.1)
(0.70710678 0.70710678 0.1)
blocks
hex (0 1 2 3 4 5) (20 20 1) simpleGrading (1 1 1)
edges
arc 1 2 (0.8 0.6 0)
arc 4 5 (0.8 0.6 0.1)
boundary
paredmovil
type wall;
faces
(0 1 4 3)
paredfija
type wall;
faces
(1 2 5 4)
(0 3 5 2)
frontalyposterior
type empty;
faces
(0 1 2)
(3 4 5)
mergePatchPairs
i got this
D:\Pruebas cfd\torta>checkmesh
/* Windows 32 and 64 bit porting by blueCAPE: http://www.bluecape.com.pt *\
| Based on Windows porting (2.0.x v4) by Symscape: http://www.symscape.com |
Build : 2.1-88b2f2ae3a0b
Exec : checkmesh
Date : Jan 20 2017
Time : 22:27:33
Host : "Lg"
PID : 1280
Case : D:/Pruebas cfd/torta
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
ter
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create polyMesh for time = 0
--> FOAM FATAL ERROR:
Cannot find file "points" in directory "polyMesh" in times 0 down to constant
From function Time::findInstance(const fileName&, const word&, const IOobjec
t::readOption, const word&)
in file db/Time/findInstance.C at line 188.
FOAM exiting
Old   January 22, 2017, 21:38
Antimony is on a distinguished road
I suspect your blockMesh did not finish properly. Looking at the blockMeshDict, the hex block is not properly defined. You need to have 8 vertices (if you are trying to get wedges, then you can have repeated vertices), but you have only 6. As a result, your blockMesh would have terminated with errors and consequently you have no mesh that checkMesh can find.
Hope this helps.
Cheers,
Antimony
Antimony is offline   Reply With Quote
Old   January 23, 2017, 09:21
Default sure
You right thanks for answer, i dont know how to build mesh with wedges.
Originally Posted by Antimony View Post
Hope this helps.
Cheers,
Antimony
Old   January 23, 2017, 21:04
Look at section 5.3.3 in this link: http://cfd.direct/openfoam/user-guide/blockMesh/
Cheers,
Antimony
Old   January 25, 2017, 14:13
Default mesh an arc
Thanks you sr, it mean if i need an arc as a section cake, i need to build an wedge plus an arc. ill try with it. its the reason the indy professor of the spoken tutorial buils a pipe using a splitter circle in salome.
Cheers,
Antimony
Old   January 26, 2017, 21:48
Solved it
I can see the circle's section, but the checkmesh fail.
FoamFile
version 2.0;
format ascii;
class dictionary;
vertices
(0 0 0)
(0.5 0 0)
(1 0 0)
(0.5 0.5 0)
(0.707 0.707 0)
(0 0 0.1)
(0.5 0 0.1)
(1 0 0.1)
(0.5 0.5 0.1)
(0.707 0.707 0.1)
blocks
hex (0 1 3 3 5 6 8 8) (20 20 1) simpleGrading (1 1 1)
hex (1 2 4 3 6 7 9 8) (20 20 1) simpleGrading (1 1 1)
edges
arc 2 4 (0.858 0.514 0)
arc 7 9 (0.858 0.514 0.1)
boundary
paredmovil
type wall;
faces
(0 1 6 5)
(1 2 7 6)
paredfija
type wall;
faces
(0 5 8 3)
(3 8 9 4)
(2 4 9 7)
frontalyposterior
type empty;
faces
(0 1 3 3)
(5 6 8 8)
(1 2 4 3)
(6 7 9 8)
mergePatchPairs
Cheers,
Antimony
ill defined primitive entry 'boundary' francisco.angel OpenFOAM Pre-Processing 16 September 8, 2022 07:11
[blockMesh] joining two cylinders sergiopb91 OpenFOAM Meshing & Mesh Conversion 1 August 29, 2016 16:41
settlingFoam unstable? bendel_boy OpenFOAM Running, Solving & CFD 38 July 8, 2016 06:07
[snappyHexMesh] snappyHexMesh and cyclic boundaries Ruli OpenFOAM Meshing & Mesh Conversion 2 December 9, 2013 07:51
weird error during blockMesh SePe OpenFOAM 1 October 25, 2010 11:31
