[snappyHexMesh] snappyHM - Boundary layer issue
Old   March 2, 2010, 14:30
Default snappyHM - Boundary layer issue
Brunno is on a distinguished road
I am working on a test case of a swirl atomizer for propulsion applications. Despite those well-known edge problems, snappyHM works fine for the most part. So far, I can't figure out how to make the boundary layer "grow" on the entire cylindrical patch and minuscule tangential channel walls (see attached figure and addLayers settings). It seems that BL attaches only when the mesh is coarse. Does anyone have a clue ?
Any help is greatly appreciated.
Brunno is offline   Reply With Quote
Old   March 2, 2010, 16:05
bjr
Ben Racine
bjr is on a distinguished road
Send a message via AIM to bjr Send a message via Skype™ to bjr
I'm working on similar issues, but am a little behind you. I will be investigating some of your layer control settings on my cylinder case asap.
bjr is offline   Reply With Quote
bjr
Ben Racine
Did you ever get boundary layer resolution and viscous drag results you liked?
Old   March 2, 2010, 16:29
Hello ben,
Thank you for the response.
Boundary layer resolution was acceptable on previous test cases. I am currently running the inviscid, single-phase flow case, so I don't have any viscous results at hand.
Old   March 2, 2010, 16:41
bjr
Ben Racine
Is there any chance you could provide any said test cases? I'm really looking to put together a case that starts from just an stl file, a blockMeshDict, and a snappyHexMeshDict that potentially yield good drag results. I think this would be a highly valuable starting point for many out there without access to commercial gridding tools to start learning quickly.
I have a location that large files can be publicly uploaded and downloaded from if needed.
http://public.me.com/ben.racine
I totally understand if you don't have the chance/time though... days are short.
Many thanks,
Ben Racine
i3enhamin@gmail.com
Old   March 2, 2010, 19:42
bjr
Ben Racine
Brunno kindly supplied me with this orifice case... http://files.me.com/ben.racine/1p3dei
Old   May 4, 2010, 06:43
Moritz Wied
Mo-ITB is on a distinguished road
sorry, i did a mistake in paraview, the mesh was even worse in 1.6.x
Mo-ITB is offline   Reply With Quote
Old   May 6, 2010, 04:45
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Hi
What is the maximum cell limit in the snappy dict?
I had similar problems once and upping the local and global cell limit made it possible to get the desired mesh.
The entries are there to prevent an explosion in cell count.
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   July 22, 2010, 07:03
stephane sanchi
openfoam_user is on a distinguished road
Hi Bruno,
did you solve you problem ? How ?
I have encountered the same problem and don't know what to do until now ?
I get layers only where there is more refinement !
Regards,
Stephane.
openfoam_user is offline   Reply With Quote
Old   July 22, 2010, 07:29
Hello Stephane,
Yes, I did solve the problem - not exactly through snappyHexMesh, but using a combination of adaptive mesh (see the dictionaries cellSetDict and refineMeshDict) based on the gradient of velocity (magU) and snappyHM. The results are not always acceptable - it's usually a trial-and-error process, but it worked for me.
Good luck !
Old   July 22, 2010, 07:36
stephane sanchi
Hi Brunno,
thanks for your advice.
I think that the problem for me is a little bit different. I would like to add several layers around my body in order to obtain Y+ near 1, if possible.
Stephane.
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
y+ = 1 boundary layer mesh with snappyHexMesh Arzed23 OpenFOAM Running, Solving & CFD 6 November 23, 2022 16:15
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
[ICEM] 3D Dynamic Mesh - Boundary layer mesh issues nathanricks ANSYS Meshing & Geometry 0 September 23, 2015 06:14
errors Fahad Main CFD Forum 0 March 23, 2004 14:20
