February 3, 2010, 10:00 |
Hex with transfinite Volume
Hi everybody,
i'm trying to mesh a section of sphere. Code:
// Convert to meters toM=1; // Characteristic length lc = 1*toM; //Height and radius //Aspect ratio Teta=D/h D=0.29; R=D*0.5*toM; h=R*toM; r=R/1.5*toM; w=R*0.5; W=R*0.6; Ru=Sqrt(R*R-W*W); Point(1) = {0,0,0,lc}; Point(2) = {R,0,0,lc}; Point(3) = {0,R,0,lc}; Point(5) = {r,0,0,lc}; Point(4) = {0,r,0,lc}; Point(6) = {Ru,0,-W,lc}; Point(7) = {0,Ru,-W,lc}; Point(8) = {r,0,-w,lc}; Point(9) = {0,r,-w,lc}; Circle (1) = {2,1,3}; Line (2) = {3,4}; Line (3) = {4,5}; Line (4) = {5,2}; Circle (5) = {2,1,6}; Circle (6) = {3,1,7}; Line (7) = {4,9}; Line (8) = {5,8}; Circle (9) = {6,1,7}; Line (10) = {7,9}; Line (11) = {9,8}; Line (12) = {8,6}; nodes1=11; nodes2=5; Transfinite Line {1,3,5,6,7,8,9,10,11} =nodes1; Transfinite Line {2,4,10,12} =nodes2; Line Loop (1) ={1,2,3,4}; Plane Surface (1)={1}; Line Loop (2) ={5,9,-6,-1}; Ruled Surface (2)={2}; Line Loop (3) ={6,10,-7,-2}; Plane Surface (3)={3}; Line Loop (4) ={7,11,-8,-3}; Plane Surface (4)={4}; Line Loop (5) ={8,12,-5,-4}; Plane Surface (5)={5}; Line Loop (6) ={9,10,11,12}; Plane Surface (6)={6}; Transfinite Surface {1} = {2,3,4,5}; Transfinite Surface {2} = {2,3,6,7}; Transfinite Surface {3} = {3,7,9,4}; Transfinite Surface {4} = {4,5,8,9}; Transfinite Surface {5} = {2,5,6,8}; Transfinite Surface {6} = {6,7,8,9}; Recombine Surface {1,2,3,4,5,6}; Surface Loop (1) = {1,2,3,4,5,-6} ; Volume (1) = {1}; Transfinite Volume {1} = {2,3,4,5,6,7,8,9}; //Physical Surface("Wall") = {2,3,4,5,37,54,59,76,81,102,103,120,125} ; //Physical Volume ("internalField") = {1}; i get following error Message: Error : Incompatible surface 3 in transfinite volume 1 Error : Cannot tetrahedralize volume with quadrangles on boundary i've no idea what could cause this problems Thanks you |
February 4, 2010, 00:59 |
The error message sounds fairly intuitive; Squares and triangles don't mix on surfaces, but hard to say without seeing it.
If you have tets' you may want to move their definitions to end of the script and put the hexes' at the beginning(long shot, but its worth a try) I will need some print screens of your problem to be of any further help. You can attach photos with the "mange attachments" button below. Best of Luck! |
February 9, 2010, 11:54 |
Pictures
If i don't use the command Recombine Surface, i can build a 3d Mesh
(see Mesh2dtirangle; Mesh3dquadangle) Without this command i can't create an 3d Mesh. (see Mesh3dquadangle, Mesh3dtriangle) thanks Mjoelnir |
February 17, 2010, 10:55 |
Problem solved
i figured out the Problem. in the transfinite Volume command the order of the points ist important.
April 1, 2010, 19:00 |
Robin Gilbert
Rep Power: 16 |
hi i have a similar problem!!
what order of points are we supposed to use?? thank you |
April 8, 2010, 08:29 |
April 8, 2010, 13:52 |
Robin Gilbert
Rep Power: 16 |
oh ya!!! thanks a lot..
thank you so much for the help!! |
May 12, 2014, 18:00 |
Incompatible surface in transfinite volume
Rep Power: 13 |
Hello, I am getting a very similar error and was wondering if you could spot what is wrong in the numbering of the volume! The error i get is "Incompatible surface 22 in transfinite volume 28". Here is my code:
lc = 0.005; length = 0.01; //chamber radius/sqrt(2) Point(1) = {0,0,0,lc}; Point(2) = {length,length,-length,lc}; Point(3) = {-length,length,-length,lc}; Point(4) = {-length,-length,-length,lc}; Point(5) = {length,-length,-length,lc}; Circle(6) = {3,1,2}; Circle(7) = {2,1,5}; Circle(8) = {5,1,4}; Circle(9) = {4,1,3}; Line(13) = {4, 1}; Line(14) = {5, 1}; Line(15) = {2, 1}; Line(16) = {3, 1}; Line Loop(17) = {13, -16, -9}; Ruled Surface(18) = {17}; Line Loop(19) = {16, -15, -6}; Ruled Surface(20) = {19}; Line Loop(21) = {15, -14, -7}; Ruled Surface(22) = {21}; Line Loop(23) = {14, -13, -8}; Ruled Surface(24) = {23}; Line Loop(25) = {8, 9, 6, 7}; Ruled Surface(26) = {25}; Surface Loop(27) = {18, 22, 26, 24, 20}; Volume(28) = {27}; Transfinite Line {13, 14, 15, 16} = 10 Using Progression 1; Woutlet = 26; Wfront = 18; Wback = 22; Wtop = 20; Wbottom = 24; WinternalVol = 28; Physical Volume("internalVol") = {WinternalVol}; Physical Surface("outlet") = {Woutlet}; Physical Surface("front") = {Wfront}; Physical Surface("back") = {Wback}; Physical Surface("top") = {Wtop}; Physical Surface("bottom") = {Wbottom}; Transfinite Surface "*"; Recombine Surface "*"; Transfinite Volume "*"; Thanks! |
March 30, 2017, 08:52 |
3D mesh in gmsh
#9 |
Bharadwaj Bhushan
Rep Power: 9 |
Hello guys,
I have a problem. I need to mesh the imported geometry. The thing is I cant change the geometry nor I can insert anything. All I can do is transfinite the line, surface and recombine it. But to get correct 3D mesh I need to transfinite the volume. I cant create the volume and also transfinite the volume selecting the ordered points. is there any other way of transfinite the volume without selecting the points ? thank you |
error messages about blockmeshing and solving | cramsdead | OpenFOAM Pre-Processing | 2 | November 11, 2014 10:53 |
[blockMesh] Mixer mesh - negative volume problem | jadtwo | OpenFOAM Meshing & Mesh Conversion | 2 | November 6, 2014 16:37 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
