[Gmsh] gmshToFoam problem.
Old   December 9, 2009, 12:50
Default gmshToFoam problem.
Nilas
nilashansen is on a distinguished road
Hi.
I'm quite new at using OpenFOAM, but I'm getting there. I'm trying to convert a gmsh mesh to FOAM format, using gmshToFoam. Every time I do so I get an error message (Shown at the end of this post).
First I thought that it was a problem with the physical entities format (see the thread gmshToFoam : problem with patch). So I tried to do the sample provide with the OpenFoam installation in applications/utilities/mesh/conversion/gmshToFoam/gmsh/.CubeVer1.msh. This did not work either.
Does any of you have suggestions of what might be the problem. I'am running ubuntu 9.10 if that can be of any help.
Thanks.
Best regards,
Nilas Hansen
nilas@nilas-desktop:~/OpenFOAM/OpenFOAM-1.6.x/applications/utilities/mesh/conversion/gmshToFoam$ gmshToFoam gmesh/CubeVer1.msh/*---------------------------------------------------------------------------*\
| \\ / O peration | Version: 1.6.x |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 1.6.x-f7a690f5c3ca
Exec : gmshToFoam gmesh/CubeVer1.msh
Date : Dec 09 2009
Time : 17:46:54
Host : nilas-desktop
PID : 2705
Case : /home/nilas/OpenFOAM/OpenFOAM-1.6.x/applications/utilities/mesh/conversion/gmshToFoam
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
--> FOAM FATAL IO ERROR:
cannot open file
file: /home/nilas/OpenFOAM/OpenFOAM-1.6.x/applications/utilities/mesh/conversion/gmshToFoam/system/controlDict at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 62.
FOAM exiting
nilashansen is offline   Reply With Quote
Old   December 10, 2009, 02:55
Alan Harrland
Alan is on a distinguished road
try:
without the .msh extension, I have found that gmsh sometimes doesnt export with the .msh extension, hence gmshtofoam can't find the file
Alan is offline   Reply With Quote
Old   December 10, 2009, 06:37
Etienne Lorriaux
elorriaux is on a distinguished road
Originally Posted by nilashansen View Post
Hi.
Date : Dec 09 2009
Time : 17:46:54
PID : 2705
nProcs : 1
Create time
cannot open file
FOAM exiting
You are trying to convert a mesh without setting up a directory path for the OF case. This error is totally normal and has nothing to do with the conversion tool.
elorriaux is offline   Reply With Quote
Old   December 15, 2009, 04:23
Eric Nutsch
ericnutsch is on a distinguished road
Send a message via Skype™ to ericnutsch
elorriaux,
I set up my directory path and a controlDict file and made it passed the error. Unfortunately I keep hitting other errors.
Just out of curiosity: do i need to put any special instructions for the gmshToFoam function in the controlDict file? (seems logical since it has to reference it, but im not sure)
Thanks for your help!
ericnutsch is offline   Reply With Quote
Old   December 15, 2009, 06:19
Alan Harrland
no, the controlDict file (and all other files not in the constant/polymesh directory) are independent of the mesh file. I'd say theres a problem with your mesh if you are still getting errors.
Old   December 28, 2009, 13:41
Eric Nutsch
Indeed, there was a problem with my mesh. Thanks for your help Alan.
Old   June 1, 2016, 16:38
Default gmshToFoam
Ajay Boora
ajayboora14 is on a distinguished road
friends my gmshToFoam command is not working
in terminal it show
gmshToFoam command not found
other all mesh conversion command are working properly
ajayboora14 is offline   Reply With Quote
Old   June 4, 2016, 20:37
coloursfordirectors is on a distinguished road
Same problem here on Ubuntu 15.10 and OpenFoam 3.0.1. Any clues what the problem might be?
coloursfordirectors is offline   Reply With Quote
Old   June 5, 2016, 06:52
Ajay Boora
Mine problem is solved it is not working because your OpenFOAM software is not installed properly so first you have to remove your existing software and reinstall it by the help of command mention in www.OpenFOAM.org
Installation tme in these command is very less and OpenFOAM will work correctly.
This is the site of OpenFOAM developers the installation command work for only ubuntu 15.10 and 14.04 if you intstalled latest version of ubuntu you have to compile manually and it will work
Old   June 5, 2016, 08:00
Hi Ajay, thanks for your quick response. I followed steps 1 to 3 under new installation on http://openfoam.org/download/3-0-1-ubuntu/ and left out step 4 as I already have ParaView installed. Is there anything else that needs to be done?
Old   June 5, 2016, 10:49
Ajay Boora
You don't need anything else to do perform a check if everything works okay than go ahead.Check all the commands are working properly or not may be this time they are working properly.
you can ask any query at https://cfdforbeginner.blogspot.in/
Its a blog for beginners in CFD
Old   June 5, 2016, 11:45
Thanks, Ajay. gmshToFoam is still not working, but I'll try to figure out.
area does not match neighbour by ... % -- possible face ordering problem St.Pacholak OpenFOAM 11 September 4, 2024 05:28
Convergence Problem in Multiphase problem (three phases) m.uzair FLUENT 0 August 2, 2018 09:23
Large problem partitioner tzy CFX 3 February 7, 2018 18:11
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
