[CAD formats] my stl surface is seen as just a line
Old   November 24, 2009, 13:27
Default my stl surface is seen as just a line
Robert Castilla
rcastilla is on a distinguished road
I have created with salome a STL simple file for a rectangular elbow:
solid elbow
facet normal -1.000000e+00 -0.000000e+00 -0.000000e+00
outer loop
vertex 0.000000e+00 6.000000e+00 1.500000e+00
vertex 0.000000e+00 6.000000e+00 -1.500000e+00
vertex 0.000000e+00 0.000000e+00 -1.500000e+00
endloop
endfacet
facet normal -1.000000e+00 -0.000000e+00 0.000000e+00
outer loop
vertex 0.000000e+00 0.000000e+00 1.500000e+00
endloop
endfacet
facet normal 0.000000e+00 -1.000000e+00 0.000000e+00
outer loop
vertex 6.000000e+00 0.000000e+00 1.500000e+00
vertex 9.000000e+00 0.000000e+00 -1.500000e+00
vertex 9.000000e+00 0.000000e+00 1.500000e+00
endloop
endfacet
outer loop
vertex 4.500000e+00 0.000000e+00 0.000000e+00
endloop
endfacet
outer loop
endloop
endfacet
facet normal -0.000000e+00 -1.000000e+00 -0.000000e+00
outer loop
endloop
endfacet
facet normal -0.000000e+00 -1.000000e+00 0.000000e+00
outer loop
endloop
endfacet
facet normal -0.000000e+00 0.000000e+00 1.000000e+00
outer loop
vertex 6.000000e+00 6.000000e+00 1.500000e+00
endloop
endfacet
facet normal 0.000000e+00 0.000000e+00 1.000000e+00
outer loop
endloop
endfacet
facet normal 0.000000e+00 1.000000e+00 0.000000e+00
outer loop
vertex 9.000000e+00 6.000000e+00 1.500000e+00
vertex 9.000000e+00 6.000000e+00 -1.500000e+00
endloop
endfacet
outer loop
vertex 4.500000e+00 6.000000e+00 0.000000e+00
endloop
endfacet
facet normal 0.000000e+00 1.000000e+00 -0.000000e+00
outer loop
endloop
endfacet
outer loop
endloop
endfacet
facet normal -0.000000e+00 1.000000e+00 0.000000e+00
outer loop
endloop
endfacet
facet normal 0.000000e+00 0.000000e+00 -1.000000e+00
outer loop
endloop
endfacet
outer loop
endloop
endfacet
facet normal 1.000000e+00 0.000000e+00 0.000000e+00
outer loop
endloop
endfacet
facet normal 1.000000e+00 -0.000000e+00 0.000000e+00
outer loop
endloop
endfacet
outer loop
vertex 6.000000e+00 0.000000e+00 7.500000e+00
endloop
endfacet
outer loop
vertex 9.000000e+00 0.000000e+00 7.500000e+00
endloop
endfacet
facet normal -1.000000e+00 0.000000e+00 0.000000e+00
outer loop
endloop
endfacet
outer loop
vertex 6.000000e+00 6.000000e+00 7.500000e+00
endloop
endfacet
outer loop
endloop
endfacet
outer loop
vertex 9.000000e+00 6.000000e+00 7.500000e+00
endloop
endfacet
outer loop
endloop
endfacet
outer loop
endloop
endfacet
outer loop
endloop
endfacet
outer loop
endloop
endfacet
endsolid elbow
The problem is that paraview sees this STL as just a line in the x-direction. Also when I want to mesh it with snappyHexMesh, I am not able to put the internal point inside the mesh, I guess that because the same problem.
Maybe has anybody encountered this strange behaviour before and can help me?
Thank you.
Robert
rcastilla is offline   Reply With Quote
Old   November 24, 2009, 14:02
Robert Castilla
news: if I export it as binary STL, problem with paraview dissapears, but with the one with snappyHexMesh still remains:
Point (3.25 3.25 0.25) is not inside the mesh or on a face or edge.
Bounding box of the mesh0 0 -1.5) (9 6 7.5)
From function refinementParameters::findCells(const polyMesh&) const
in file autoHexMesh/autoHexMeshDriver/refinementParameters/refinementParameters.C at line 104.
Some idea?
Thanks again
Robert
Old   January 6, 2010, 02:30
amgode's Avatar
Amol
amgode is on a distinguished road
The STL file seems to be fine.......There does not seem to a problem.......
This is some part of the snappyHexMeshDict I used.......
geometry
elbow.stl
type triSurfaceMesh;
name elbow;
refinementSurfaces
elbow
// Surface-wise min and max refinement level
level (3 3);
refinementRegions
elbow
mode distance;
levels ((0.1 3) (0.5 2) (1 1));
locationInMesh (4.0 2.0 2.0);
debug 0;
mergeTolerance 1E-4;
But since the geometry is not closed, there will be mesh in the region between blockMesh and the elbow........If its not required you need to use a closed geometry.
Regards,
Amol
amgode is offline   Reply With Quote
[Gmsh] 3D Mesh conversion from gmsh-2.5.0 to OpenFOAM Ancioi OpenFOAM Meshing & Mesh Conversion 17 January 9, 2019 00:50
[Other] Compiling hacFoam (Ubuntu 10.04)(OF2.0.0)(LAMMPS13Jul2010)) Henrik_E OpenFOAM Installation 3 September 29, 2016 17:16
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 09:48
OpenFOAM15 installables are incomplete problem with paraFoam tryingof OpenFOAM Bugs 17 December 7, 2008 05:41
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 05:26
