[blockMesh] Creating O-meshes
Old   October 26, 2009, 09:44
Default Creating O-meshes
MadsR's Avatar
Mads Reck
MadsR is on a distinguished road
Hi.
I need to make an O-mesh using blockMesh, is someone able to help me out?
I need it for an airfoil, but a cylinder-example or the like would be great.
Thanks a lot!
/Mads
Online free airfoil-mesher for OpenFOAM here
MadsR is offline   Reply With Quote
Old   October 26, 2009, 12:56
akidess's Avatar
Anton Kidess
There you go. This mesh has refinement towards both ends of the cylinder, so it could be simplified to use only five blocks.
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 0.025;
vertices
    (0.21 0.21 0)
    (-0.21 0.21 0)
    (-0.21 -0.21 0)
    (0.21 -0.21 0)
    (0.21 0.21 1.2)
    (-0.21 0.21 1.2)
    (-0.21 -0.21 1.2)
    (0.21 -0.21 1.2)
    (0.353553 0.353553 0)
    (-0.353553 0.353553 0)
    (-0.353553 -0.353553 0)
    (0.353553 -0.353553 0)
    (0.353553 0.353553 1.2)
    (-0.353553 0.353553 1.2)
    (-0.353553 -0.353553 1.2)
    (0.353553 -0.353553 1.2)
    (0.21 0.21 0.6)
    (-0.21 0.21 0.6)
    (-0.21 -0.21 0.6)
    (0.21 -0.21 0.6)
    (0.353553 0.353553 0.6)
    (-0.353553 0.353553 0.6)
    (-0.353553 -0.353553 0.6)
    (0.353553 -0.353553 0.6)
blocks
    // center block 1
    hex (2 3 0 1 18 19 16 17) (23 23 53) simpleGrading (1 1 2.5)
    // right 1
    hex (3 11 8 0 19 23 20 16) (17 23 53) simpleGrading (1 1 2.5)
    // top 1
    hex (1 0 8 9 17 16 20 21) (23 17 53) simpleGrading (1 1 2.5)
    // left 1
    hex (10 2 1 9 22 18 17 21) (17 23 53) simpleGrading (1 1 2.5)
    // bottom 1
    hex (10 11 3 2 22 23 19 18) (23 17 53) simpleGrading (1 1 2.5)
    // center block 2
    hex (18 19 16 17 6 7 4 5) (23 23 53) simpleGrading (1 1 0.4)
    // right 2
    hex (19 23 20 16 7 15 12 4) (17 23 53) simpleGrading (1 1 0.4)
    // top 2
    hex (17 16 20 21 5 4 12 13) (23 17 53) simpleGrading (1 1 0.4)
    // left 2
    hex (22 18 17 21 14 6 5 13) (17 23 53) simpleGrading (1 1 0.4)
    // bottom 2
    hex (22 23 19 18 14 15 7 6) (23 17 53) simpleGrading (1 1 0.4)
edges
    arc 11 8 (0.5 0 0)
    arc 8 9 (0 0.5 0)
    arc 9 10 (-0.5 0 0)
    arc 10 11 (0 -0.5 0)
    arc 15 12 (0.5 0 1.2)
    arc 12 13 (0 0.5 1.2)
    arc 13 14 (-0.5 0 1.2)
    arc 14 15 (0 -0.5 1.2)
    arc 23 20 (0.5 0 0.6)
    arc 20 21 (0 0.5 0.6)
    arc 21 22 (-0.5 0 0.6)
    arc 22 23 (0 -0.5 0.6)
patches
    wall sideWalls
        (11 23 20 8)
        (23 15 12 20)
        (8 20 21 9)
        (20 12 13 21)
        (9 10 22 21)
        (21 22 14 13)
        (10 11 23 22)
        (22 23 15 14)
    wall bottomWall
        (2 3 0 1)
        (3 11 8 0)
        (0 8 9 1)
        (2 1 9 10)
        (2 10 11 3)
    wall topWall
        (6 7 4 5)
        (7 15 12 4)
        (4 12 13 5)
        (6 5 13 14)
        (6 14 15 7)
mergePatchPairs
Old   October 29, 2009, 05:40
MadsR's Avatar
Mads Reck
Thanks Anton.
I am trying to extend this to a mesh around an airfoil, and it's pretty hard (well, in principle it's simple, but it's so tedious work :-) ). You wouldn't happen to have a version for an airfoil which might be easier to extend? I'd like to make an automatic blockMeshDict generator for airfoil meshes (say, from a x,y,z airfoil-data file).
/Mads
Old   October 29, 2009, 13:00
akidess's Avatar
Anton Kidess
Unfortunately that's all I have, I've never tried to mesh an airfoil. Slightly offtopic, but isn't the mesh you need C-type? Because it collapses at the thin side of the foil?
Wouldn't it be possible to have your airfoil data-file as STL, and then just make the mesh with snappyHexMesh?
Old   October 30, 2009, 03:39
MadsR's Avatar
Mads Reck
Anton, you are absolutely right about the C-mesh, typically used. But my airfoil has a blunt trailing edge (it's truncated and sharp), and an o-mesh is probably best in such cases.
I have tried snappyHexMesh (I think this tool is great, and I am looking forward to it being improved even more) but it has trouble with capturing the sharp trailing edge AND having it making boundary layers never really worked out for me...
blockmesh, o-mesh
[SOWFA] NREL SOWFA ABLTerrainSolver tutorial problem cico0815 OpenFOAM Community Contributions 36 February 3, 2022 12:54
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 14:38
creating CHT case from two adjacent nonconformal meshes skuznet OpenFOAM Pre-Processing 0 June 9, 2014 16:33
[blockMesh] Tutorial for Creating Simple 3D Meshes jonlemur OpenFOAM Meshing & Mesh Conversion 4 August 8, 2007 14:20
