[blockMesh] DNS mesh
Old   October 9, 2009, 11:12
Default DNS mesh
Suresh kumar Kannan
kumar is on a distinguished road
Hello everybody,
I am working on making a DNS mesh for simulating the break up of a liquid sheet. Initially i had problem in generating the meshes on a 32 bit machine using blockMesh, so i moved to 64 bit. Then my blockMesh for running, but it takes unusually large time to make the mesh. But finally I had a mesh written and when i wanted to check the mesh it again takes unusually long time to run the checkMesh and it is stuck at this point
Create time
Create polyMesh for time = constant
Time = constant
Mesh stats
internal points: 0
faces: 32607050
internal faces: 16292950
cells: 8150000
boundary patches: 6
point zones: 0
face zones: 0
cell zones: 0
Number of cells of each type:
hexahedra: 8150000
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 0
polyhedra: 0
Checking topology...
Boundary definition OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
Patch Faces Points Surface topology
inlet 50 102 ok (non-closed singly connected)
outlet 4050 8102 ok (non-closed singly connected)
channelWalls 2000 4004 ok (non-closed singly connected)
walls 4000 8004 ok (non-closed singly connected)
sides 4000 8004 ok (non-closed singly connected)
I think there are large number of default cells which are set to empty and it is checking those meshes. But i want visualize and check if my mesh is ok or not.
But i also tried to visualise the mesh in ParaFoam but i could not load the file itself, paraFoam just hangs after i ask it to display the mesh.
I have approxiamtely 8 million cells in my mesh. So i want to know if anybody has faced similar kinds of problems while trying to visualize meshes with large number of cells. Is there any specific way to visualize meshes with large number of cells.
bye
with regards
K.Suresh kumar
kumar is offline   Reply With Quote
Old   October 30, 2009, 01:02
lakeat's Avatar
Daniel WEI (老魏)
lakeat is on a distinguished road
Send a message via Skype™ to lakeat
Are you sure about your machine? is the memory large enough? have you coarsen your mesh so that see whether in this way paraFoam can handle it or not, so as to exclude the problem from the man-made reasons?
I use 6G memory to handle my 2 million mesh, and it is really a hard time, but it won't stuck but did take a long time.
CheckMesh some times will report errors, but even then it is okay for my case, I can still run my case.
So my little advice is to try a coarsened one, and see what happens?
Daniel WEI
Boeing Research & Technology - China
Beijing, China
Email
lakeat is offline   Reply With Quote
Old   April 9, 2010, 06:04
Default BlockMesh maximum number cells
Aldo Iannetti
aldo.iannetti is on a distinguished road
Hi foamers,
I'm trying to generate a 100 Mln cells grid for a DNS application. I can't do that yet. Is there anybody who has made it? How to do? How to avoid the lack of memory? Can blockMesh run in parallel?
thanks
aldo.iannetti is offline   Reply With Quote
y+ = 1 boundary layer mesh with snappyHexMesh Arzed23 OpenFOAM Running, Solving & CFD 6 November 23, 2022 16:15
Filtering DNS solutions Vs projecting filtered DNS solution juliom Main CFD Forum 5 May 19, 2016 17:06
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 08:05
