[blockMesh] Problem using paraFoam to view cavityGrade mesh file |
September 24, 2009, 02:53 |
anonymous
Rep Power: 17 |
I am having difficulty running paraFoam to view the mesh file for the cavityGrade case available in the openFoam tutorial. I get the following error message when I execute the command "paraFoam" within the case directory. ************************************************** ****** ERROR: In /home/dm2/henry/OpenFOAM/OpenFOAM-1.6/applications/utilities/postProcessing/graphics/PV3FoamReader/PV3FoamReader/vtkPV3FoamReader.cxx, line 189 vtkPV3FoamReader (0x8add298): could not find valid OpenFOAM mesh ERROR: In /home/dm2/henry/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/VTK/Filtering/vtkExecutive.cxx, line 757 vtkCompositeDataPipeline (0x8a45e60): Algorithm vtkPV3FoamReader(0x8add298) returned failure for request: vtkInformation (0x8aeb258) Debug: Off Modified Time: 82767 Reference Count: 1 Registered Events: (none) Request: REQUEST_INFORMATION FORWARD_DIRECTION: 0 ALGORITHM_AFTER_FORWARD: 1 ************************************************** ******** Please note that I am using OpenFoam 1.6 for lunix 32 bit platform in Ubuntu 9.04. If you have a solution, please let me know. Thanks. Felik9 Last edited by felik9; September 24, 2009 at 02:57. Reason: Title revision |
September 27, 2009, 16:31 |
Found Solution
anonymous
Rep Power: 17 |
The problem was that I did not run blockMesh first, then paraFoam. Thanks for viewing my post |
cavitygrade, error, parafoam |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 04:30 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 02:22 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 22:53 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 13:41 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
