August 22, 2009, 09:58 |
generate a graded pipe mesh.
Jim Enright
I'm trying to generate a 'doughnut' pipe mesh with different levels of refinement at different parts of the pipe using blockMesh. I want the mesh to be fine in the middle of the pipe and coarse at the inlet and outlet sides. I create the pipe mesh using a script that allows me to specify the outer and inner radius of the pipe (attached). I've used the refineHexMesh utility on cells within a bounding box near the centre of the pipe. I also tried snappyHexMesh to refine the region inside a searchable box. However, both of these seemed to refine in only one direction and the edges from the refined region didn't connect well with the non-refined region. I hope you can see this in the attached screenshot. Does anyone have any suggestions? Is it possible to modify my script to get refinement in a specific part of the pipe? Thanks, Jim |
blockmesh, mesh quality, refinement |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
Too diffusive result on Delaunay type mesh for pipe | AlmostSurelyRob | OpenFOAM Running, Solving & CFD | 7 | October 8, 2018 14:34 |
[ICEM] How to generate sunstructured "all-tri patch-dependant" surface mesh in ICEM? | jash | ANSYS Meshing & Geometry | 19 | July 23, 2013 19:48 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 22:11 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
