[mesh manipulation] stitchMesh duplicate point error
Old   August 13, 2009, 11:47
Default stitchMesh duplicate point error
romant's Avatar
Roman Thiele
romant is on a distinguished road
Hej,
when using stitchMesh I run into an error about duplicate points. The patches that are supposed to be stitched are two pipes (see picture in attachement). The mesh was created with snappyHexMesh, this might explain the kinks at the ends of the two pipes. The error that occurs while reading the volfields is
Duplicate point found in cut face. Error in the face cutting algorithm for global face 4(126702 151688 189487 151690) local face 4(303 306 307 308)
Slave size: 28704 Master size: 39064 index: 131.
Face: 5(126702 151688 189487 220642 220682)
Can it be, that because the endfaces of those two pipes are identical, that this error occurs, and if this is the case, how can i avoid this error?
~roman
romant is offline   Reply With Quote
duplicate point, error, stitchmesh
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 08:43
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 08:11
[General] 2 datas on one plot Akuji ParaView 46 December 1, 2013 15:06
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 06:07
