[Commercial meshers] fluentMeshToFoam: "fluent patch type shadow not recognised"
Old   October 8, 2012, 09:11
sivakumar selvaraju
sivakumar is on a distinguished road
Send a message via Skype™ to sivakumar
Hello blacksquirrel,
can you please give me your mail id, so that i will send my mesh file via sendspace.
thanks,
Siva
sivakumar is offline   Reply With Quote
Old   October 8, 2012, 09:42
sivakumar selvaraju
I have up loaded the file in send space, I think you have received the email from send space.
please have a look and tell me what was wrong.
Thank you very much for your time.
Siva
Old   October 8, 2012, 10:06
blacksquirrel is on a distinguished road
Ok, I received your mesh. I've only used simple (rectangular) channels for my simulations, so now I'm guessing, too.
Somewhere you have to tell OpenFOAM that it needs to rotate patch ILR to match ILR_shadow.
You can try this:
transform rotational;
rotationAxis (1 0 0); //adjust this to your case
//rotationCentre (0 0 0);
If this doesn't work, then I'm clueless. I'm sorry.
blacksquirrel is offline   Reply With Quote
Old   October 8, 2012, 13:33
sivakumar selvaraju
Thanks for your reply, I want try the previous reply from you.
you said that we can create the cyclic BC using the createPatch utility.
I am bit confused to edit the createPatchDict.
can you please help me to edit.
after creating the wall boundary my boundary file look like this,
12
outlet
type patch;
nFaces 6400;
startFace 6276800;
inlet
type patch;
nFaces 6400;
startFace 6283200;
top2
type wall;
nFaces 16000;
startFace 6289600;
top1
type wall;
nFaces 2400;
startFace 6305600;
top0
type wall;
nFaces 8000;
startFace 6308000;
center1
type wall;
nFaces 16000;
startFace 6316000;
center0
type wall;
nFaces 8000;
startFace 6332000;
OR
type wall;
nFaces 16000;
startFace 6340000;
OL
type wall;
nFaces 16000;
startFace 6356000;
FAN
type wall;
nFaces 7200;
startFace 6372000;
IFR
type wall;
nFaces 8000;
startFace 6379200;
IFL
type wall;
nFaces 8000;
startFace 6387200;
in that I am able to see the "patch" to "cyclic" but how to do "wall" to "cyclic"
can you please guide me.
Thanks and Regards,
Sivakumar
Old   October 8, 2012, 15:57
sivakumar selvaraju
Hi Guys,
I have solved the problem, Its simple issue.
I didn’t edit the 0 folder files according to my boundary file.
after editing the 0 folder files, now I am able to see the mesh in paraFoam.
Thank you very much for your help.
soon i will come with another problem.
thank you guys,
Sivakumar
Old   March 29, 2017, 05:09
Default please help me to sort out this problem
  #26
yining song
syn1993530 is on a distinguished road
Create time
--> FOAM FATAL IO ERROR:
cannot open file
file: /home/syn/solids4foamphilip/tutorials/nonLinGeomSolidFoam/plateHole/system/system/controlDict at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 61.
FOAM exiting
__________________________________________________ ___________________________
please help me to sort out this problem,
And what are the further steps I need to follow?
Thank you,
SYN
syn1993530 is offline   Reply With Quote
Old   March 29, 2017, 05:16
Julien Schaguene
JulienS is on a distinguished road
Are you trying to lauch FluentMeshToFoam from your system folder?
That can explain that it cannot find the "controlDict" located in a "system/system/" folder. You have to lauch fluentMeshToFoam from the root of your case.
JulienS is offline   Reply With Quote
Old   March 29, 2017, 05:31
yining song
Thank you for your help.And I have lauch FluentMeshToFoam from my system folder.However, it still exist this problem.
syn@syn-Lenovo:~$ fe32
syn@syn-Lenovo:~$ cd /home/syn/solids4foamphilip/tutorials/nonLinGeomSolidFoam/plateHole/system/
syn@syn-Lenovo:~/solids4foamphilip/tutorials/nonLinGeomSolidFoam/plateHole/system$ fluentMeshToFoam 1.msh
| \\ / F ield | foam-extend: Open Source CFD |
| \\ / O peration | Version: 3.2 |
| \\ / A nd | Web: http://www.foam-extend.org |
| \\/ M anipulation | For copyright notice see file Copyright |
Build : 3.2-334ba0562a2c
Exec : fluentMeshToFoam 1.msh
Date : Mar 29 2017
Time : 16:31:08
Host : syn-Lenovo
PID : 3648
CtrlDict : "/home/syn/solids4foamphilip/tutorials/nonLinGeomSolidFoam/plateHole/system/system/controlDict"
Case : /home/syn/solids4foamphilip/tutorials/nonLinGeomSolidFoam/plateHole/system
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
cannot open file
FOAM exiting
Old   March 29, 2017, 05:56
Julien Schaguene
Maybe my previous advice was not clear enough.
You cannot launch FluentMeshToFoam from the system folder. You have to launch it from the root of your case!
reactingMultiphaseEulerFoam tonnykz OpenFOAM Running, Solving & CFD 2 June 15, 2020 03:09
Near wall treatment in k-omega SST Arnoldinho OpenFOAM Running, Solving & CFD 38 March 8, 2017 14:48
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
[Commercial meshers] Fluent msh and cyclic boundary cfdengineering OpenFOAM Meshing & Mesh Conversion 48 January 25, 2013 04:28
[swak4Foam] Air Conditioned room groovyBC Sebaj OpenFOAM Community Contributions 7 October 31, 2012 15:16
