[Salome] Conversion of a cylinder with IdeasUnvToFoam |
July 27, 2009, 09:40 |
David GISEN
Rep Power: 17 |
Dear community,
I need your help to see if i am making a fundamental mistake in learning OF. I want to simulate the water stream around a cylinder in a simple channel. The geometry and mesh was created using Salome. After the conversion into OF format with IdeasUnvToFoam, the geometry is kinda messy. It seems that the cylinder is not translated correctly, neither are the holes in the top and bottom faces. What do I need to change to make the conversion running? (Checkmesh does not complain about the converted mesh). I'm using Ubuntu 9, OF 1.5 and Salome 4.1.4. Thank you in advance, David http://www.abload.de/image.php?img=wireframeah4z.png http://www.abload.de/image.php?img=meshbcy8.png http://www.abload.de/image.php?img=paraviewmgp4.png (sorry that I posted only hyperlinks, the preview post tool removed my image links every time) |
September 16, 2009, 10:36 |
David GISEN
Rep Power: 17 |
I found the solution by accident: it's a problem with the language variable, which has to been set to "C" in operating systems not using english as default language.
write LANG=C in your .bashrc file located invisible in your HOME directory. then restart terminal and voila! detailed information about this topic: http://www.cfd-online.com/Forums/ope...tml#post218694 |
CFD by anderson, chp 10.... supersonic flow over flat plate | varunjain89 | Main CFD Forum | 18 | May 11, 2018 08:31 |
Drag force coefficient too high for a flow past a cylinder using komega sst | Scabbard | OpenFOAM Running, Solving & CFD | 37 | March 21, 2016 17:16 |
Forces Acting on a Rotating Cylinder (Moving Mesh) | dreamchaser | CFX | 5 | April 25, 2015 07:01 |
[Other] ideasUnvToFoam for flow past cylinder | R_21 | OpenFOAM Meshing & Mesh Conversion | 0 | October 3, 2014 07:33 |
[blockMesh] Specifying boundary faces failes in blockMesh | blaise | OpenFOAM Meshing & Mesh Conversion | 0 | May 10, 2010 04:56 |
