July 1, 2009, 11:44 |
splitMeshRegion
Kyian Barrat
Rep Power: 17 |
Hi Foamers,
Im not sure to post the thread in the right place, so, forgive me... Im working on a case where i have 4 regions (3 solids and 1 fluid). So I try to understand chtMultiRegionFoam solver following the same steps as the tutorial multiRegionHeater. But when i run the application splitMeshRegion, it finds only 2 regions (1 solid 1 fluid). It's strange because in the step before (the application setsToZone), it finds 4 Zones. I well defined 4 regions in RegionProperties. I dont know where it can come from... Can someone have an explanation? What I have to do to fix it? Thanks in advance Kyian |
July 2, 2009, 06:02 |
Kyian Barrat
Rep Power: 17 |
I found the problem... there was a mistake in the makeCellSet file... Sorry for polluting the forum |
[mesh manipulation] splitMeshRegion | FekrKon | OpenFOAM Meshing & Mesh Conversion | 27 | June 23, 2020 14:57 |
[Other] splitMeshRegion problem(cell in multi zones) | huangkai | OpenFOAM Meshing & Mesh Conversion | 0 | April 10, 2019 11:52 |
[mesh manipulation] splitMeshRegion for chtMultiRegionFoamCase | Bob! | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2017 19:08 |
cht splitMeshRegion but keeping porous cellZones | klilla | OpenFOAM Pre-Processing | 3 | November 19, 2013 09:32 |
[mesh manipulation] SplitMeshRegion | ivan_cozza | OpenFOAM Meshing & Mesh Conversion | 2 | October 29, 2008 07:38 |
