[snappyHexMesh] snappyHexMesh - Floating point error |
March 22, 2009, 21:53 |
James
Rep Power: 17 |
I've been using snappyHexMesh for relatively simple geometries: about 50 stl files and about 1M cells with success. However I moved to more complex geometries involving about 200 stl files and from 5M to 10 M cells and snappy is now throwing me the error below. is there a limitation on the size and number of STL files that 'snappy' can handle?
The computer I am using is: HP workstation 8600, intel Xeon (4 cores) /w Linux RedHat, 16GB RAM 1TB Hard Drive, and OpenFOAM 1.5 thanks for your help... jim Code:
Added patches in = 0.01 s Selecting decompositionMethod simple Overall mesh bounding box : (-500 -2500 400) (6500 2500 3000) Relative tolerance : 1e-06 Absolute matching distance : 0.00898666 Determining initial surface intersections ----------------------------------------- Edge intersection testing: Number of edges : 83700 Number of edges to retest : 83700 Number of intersected edges : 1517 Calculated surface intersections in = 29.73 s Initial mesh : cells:27000 faces:83700 points:29791 Cells per refinement level: 0 27000 Refinement phase ---------------- Found point (410 -1170 1100) in cell 7413 on processor 0 Reading external feature lines. Read feature lines in = 0 s Surface refinement iteration 0 ------------------------------ Marked for refinement due to surface intersection : 1873 cells. Marked for refinement due to curvature/regions : 0 cells. Determined cells to refine in = 0.03 s Selected for refinement : 1873 cells (out of 27000) Edge intersection testing: Number of edges : 127149 Number of edges to retest : 56120 Number of intersected edges : 6697 Refined mesh in = 1.68 s After refinement surface refinement iteration 0 : cells:40111 faces:127149 points:47112 Cells per refinement level: 0 25127 1 14984 Surface refinement iteration 1 ------------------------------ Marked for refinement due to surface intersection : 298 cells. Marked for refinement due to curvature/regions : 0 cells. Determined cells to refine in = 0.76 s Selected for refinement : 332 cells (out of 40111) Edge intersection testing: Number of edges : 134700 Number of edges to retest : 18673 Number of intersected edges : 7216 Refined mesh in = 1.07 s After refinement surface refinement iteration 1 : cells:42435 faces:134700 points:50037 Cells per refinement level: 0 24923 1 16488 2 1024 Surface refinement iteration 2 ------------------------------ Marked for refinement due to surface intersection : 494 cells. #0 Foam::error::printStack(Foam::Ostream&) in "/home/jimi/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/jimi/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: [0xb7feb400] #3 Foam::meshRefinement::markSurfaceCurvatureRefinement(double, int, Foam::List<int> const&, Foam::Field<Foam::Vector<double> > const&, Foam::List<int>&, int&) const in "/home/jimi/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libautoMesh.so" #4 Foam::meshRefinement::refineCandidates(Foam::Vector<double> const&, double, Foam::PtrList<Foam::featureEdgeMesh> const&, Foam::List<int> const&, bool, bool, bool, bool, int, int) const in "/home/jimi/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libautoMesh.so" #5 Foam::autoRefineDriver::surfaceOnlyRefine(Foam::refinementParameters const&, int) in "/home/jimi/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libautoMesh.so" #6 Foam::autoRefineDriver::doRefine(Foam::dictionary const&, Foam::refinementParameters const&, bool) in "/home/jimi/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libautoMesh.so" #7 main in "/home/jimi/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/snappyHexMesh" #8 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #9 Foam::regIOobject::writeObject(Foam::IOstream::streamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/home/jimi/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/snappyHexMesh" Floating point exception |
March 23, 2009, 06:17 |
Mattijs Janssens
Rep Power: 26 |
There is no limitation on number of surfaces. (a 32 bit version does have the 2Gb memory limit though). Have you tried 1.5.x instead of 1.5? There are some fixes in there relating to snappyHexMesh. If problem still persists please report a bug in OpenFOAM-bugs.
March 24, 2009, 18:52 |
#3 | |
James
Rep Power: 17 |
Thanks Mattijs, I havenīt tested 1.5.x version yet, I will do that and post back my findings, however for 'snappy' version 1.5 it seems that if an stl file is large (say>200MB) then problems may occur, I haven't confirmed this and I need to make more trials in order to be sure. cheers jim |
June 23, 2009, 07:53 |
Bob De Clercq
Rep Power: 17 |
Hi James,
I encountered the same error message as you obtained for an stl of a simple cylinder in OF1.5 (but already after surface refinement interation 1). This is my first case with snappyHexMesh so I also may be due to other reasons but the problem seems identical though. Did OF1.5 solve your problem or is it a bug? Many thanks. Regards, Bob |
September 19, 2009, 15:14 |
James
Rep Power: 17 |
This is what I've seen so far.
(1)=============================================== ===== I am using CFD-VisCART to quick fix the STL surfaces (shrink wrap) and to make relevant parts watertight which I then re-export as STLs. If this is done properly snappyHexMesh(1.5) will not complain and the meshing procedure will finish normally. I am producing grids from 3 to 5M cells for the moment and for testing purposes. The full geometry is composed of about 100 STL files. I pretend to use grids ranging from 10 to 13M cells. I am now investigating the mesh quality controls and layer controls because it seems that the grids I am obtaining are not of enough quality and in consequence the solver diverges. So far I've tested simpleFoam and turbFoam (k-e) for automotive applications. (2)=============================================== ===== I am also testing snappyHexMesh v1.6. However I am getting again the floting point exception but now when snappyHexMesh reaches the addLayer part of the algorithm (see below). Of course you can obtain the mesh if you disable the addLayer keyword. Code:
Handling cells with warped patch faces ... Set displacement to zero on 3 warped faces since layer would be > 0.5 of the size of the bounding box. patch faces layers avg thickness[m] near-wall overall ----- ----- ------ --------- ------- pm_in_drive 14 1 0.00516 0.00516 pm_in_drive_621 33 1 0.0223 0.0223 Trims_Front 52 1 0.0343 0.0343 Hood_Under 13 1 0.0433 0.0433 drive_647 17 1 0.00516 0.00516 Bumper_front 49 1 0.0221 0.0221 #0 Foam::error::printStack(Foam::Ostream&) in "/home/jimi/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/jimi/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: #3 Foam::autoLayerDriver::addLayers(Foam::layerParameters const&, Foam::dictionary const&, int, Foam::motionSmoother&, Foam::decompositionMethod&, Foam::fvMeshDistribute&) in "/home/jimi/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libautoMesh.so" #4 Foam::autoLayerDriver::doLayers(Foam::dictionary const&, Foam::dictionary const&, Foam::layerParameters const&, Foam::decompositionMethod&, Foam::fvMeshDistribute&) in "/home/jimi/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libautoMesh.so" #5 main in "/home/jimi/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/snappyHexMesh" #6 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #7 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/i386/elf/start.S:122 Floating point exception cheers j |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 20:43 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 10:31 |
[blockMesh] error EOF in blockMesh | Ahmed Khattab | OpenFOAM Meshing & Mesh Conversion | 7 | May 17, 2012 01:37 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 11:23 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
