[Netgen] Compiling Netgen on Fedora Core is driving me crazy
Old   November 8, 2007, 05:26
Default Compiling Netgen on Fedora Core is driving me crazy
Jan Goebel
jango is on a distinguished road
Hello Everybody,
I am trying to compile the netgen scources from
http://www.hpfem.jku.at/netgen/
on a Fedora Core 6- System without success. after setting the Environment variables and adding the
missing line in meshtype.hpp (class mesh;), as described in the OF-Message Board thread "Installation of Netgen in SuSE Linux 9.2" I still have problems compiling the togl- module receiving the following error messages:
./libsrc/include/../../togl/togl.h:152: error: forward declaration of 'struct Togl'
togl/togl.cpp:1259: error: invalid use of incomplete type 'struct Togl'
togl/togl.cpp:1260: error: invalid use of incomplete type 'struct Togl'
togl/togl.cpp:1267: error: invalid use of incomplete type 'struct Togl'
togl/togl.cpp:1269: error: invalid use of incomplete type 'struct Togl'
togl/togl.cpp:1280: error: invalid use of incomplete type 'struct Togl'
togl/togl.cpp:1281: error: invalid use of incomplete type 'struct Togl'
togl/togl.cpp:1285: error: invalid use of incomplete type 'struct Togl'
togl/togl.cpp:1289: error: invalid use of incomplete type 'struct Togl'
togl/togl.cpp:1290: error: invalid use of incomplete type 'struct Togl'
togl/togl.cpp:1296: error: invalid use of incomplete type 'struct Togl'
togl/togl.cpp:1301: error: invalid use of incomplete type 'struct Togl'
togl/togl.cpp:1304: error: invalid use of incomplete type 'struct Togl'
togl/togl.cpp: In function 'int Togl_MakeWindowExist(Togl*)':
togl/togl.cpp:1366: error: 'TkWindow' was not declared in this scope
togl/togl.cpp:1366: error: 'winPtr' was not declared in this scope
togl/togl.cpp:1366: error: expected primary-expression before ')' token
togl/togl.cpp:1366: error: expected `;' before 'togl'
togl/togl.cpp:1367: error: 'winPtr2' was not declared in this scope
togl/togl.cpp:1395: error: invalid use of incomplete type 'struct Togl'
I don` t know what the problem is, can anyone of you help me please ? Or does anybody have the same problems ??
thank you,
Jan
jango is offline   Reply With Quote
Old   November 8, 2007, 06:26
Default Hi Jan, you can find useful
Tommaso Lucchini
lucchini is on a distinguished road
Hi Jan,
you can find useful info on some forums. Just type something like "netgen togl fedora" on google and you can find what you need.
However, I managed to compile netgen. If you have an ftp site I can upload there my modified version.
Bye
Tommaso
lucchini is offline   Reply With Quote
Old   November 8, 2007, 07:10
Default Hello Jan, A Good day to yo
Philippose Rajan
philippose will become famous soon enough
Hello Jan,
A Good day to you!
I have been using Netgen since Fedora Core 5 (currently running on Fedora 7, and will be shifting to Fedora 8).
I am currently at work, but once I get back home this evening, I can give you the settings I use for compiling netgen from CVS.
I recompile netgen quite often, so we should be able to solve the problems you have.
Enjoy!
Philippose
philippose is offline   Reply With Quote
Old   November 9, 2007, 14:29
Default Hello again, I think Tommas
Philippose Rajan
Hello again,
I think Tommaso's idea would be the best in my case too... I have made the required modifications for compiling Netgen v4.5 on Fedora 7, and have also enabled the OpenCascade support which allows for the import of STEP/IGES data.
It might be easier to just zip it up and post it somewhere rather than trying to explain the process (unless you really want to know :-)!)... its not too complex at all...!
Philippose
solving a conduction problem in FLUENT using UDF Avin2407 Fluent UDF and Scheme Programming 1 March 13, 2015 03:02
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Error compiling 1.6.x on Fedora 12 vnpenguin OpenFOAM Installation 7 July 24, 2012 15:52
FEDORA CORE and PARALLEL processing Tuks CFX 2 August 20, 2005 12:05
FEDORA core 2 and FLUENT tuks FLUENT 2 July 13, 2005 01:23
