[Technical] Polyhedral mesh generation
Like Tree9Likes
Old   December 3, 2007, 15:25
Default I would like to have a look at
  #21
lillberg's Avatar
Eric Lillberg
lillberg is on a distinguished road
Send a message via Skype™ to lillberg
I would like to have a look at it also, allthough I don't think I have much to contribute, now that you've got professional help ;-)
eric.lillberg@afcosult.com
/Eric
lillberg is offline   Reply With Quote
Old   December 3, 2007, 15:31
Default wrong e-mail, should be eri
  #22
lillberg's Avatar
Eric Lillberg
eric.lillberg@afconsult.com
Old   December 3, 2007, 17:19
Default Problem was the cellZones. The
  #23
Mattijs Janssens
mattijs is on a distinguished road
Problem was the cellZones. They are not mapped so they had illegal content after the conversion. It converts ok if I remove the cellZones file.
It is not going to be trivial to map the cell zones. I assume you want to have interface inbetween the cellZones to remain the same when converting so those internal faces would have to be treated like boundary faces.
mattijs is offline   Reply With Quote
Old   December 3, 2007, 17:40
Default You are right Mattijs. So at t
  #24
BastiL
bastil is on a distinguished road
You are right Mattijs. So at the moment only possiblity is to delete cellzones?
BastiL
bastil is offline   Reply With Quote
Old   December 4, 2007, 04:51
Default Hi guys. Another question.
  #25
Frank Bos
lr103476 is on a distinguished road
Hi guys.
Another question. Did anyone perform a flow simulation with a moving polyMesh. In the past I just tried icoDyMFoam on a polyMesh, but I did not get any convergence, at least much much slower compared to block structured hex-mesh.
Frank
Frank Bos
lr103476 is offline   Reply With Quote
Old   December 8, 2007, 06:04
Default Hello guys, I also have a pro
  #26
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Hello guys,
I also have a problem (most likely a newbie one): although the polyDualMesh does the job, I almost get those nice looking polyhedra:
I converted those tetrahedra into polyhedra using:
polyDualMesh ./ testMRF 89
and then I used
foamToVTK ./ testMRF -time 0
followed by paraview-3.2.1.
Is there something I missed?
Dragos
dmoroian is offline   Reply With Quote
Old   December 8, 2007, 22:20
Default Hi Dragos, The easiest way is
  #27
Takuya OSHIMA
7islands is on a distinguished road
Hi Dragos,
The easiest way is to add -allPatches to your foamToVTK command line
foamToVTK . testMRF -time 0 -allPatches
and read allPatches*.vtk.
Takuya
Alhasan and toma_ like this.
7islands is offline   Reply With Quote
Old   December 9, 2007, 02:16
Default Indeed it works great! http:/
  #28
dmoroian's Avatar
Dragos
Thanks Takuya!
...if I only had the courage to look with paraview at some of the patches that it creates by default...
Though, I'm curious now: what do I see in the above picture, from the previous message, if not the polyhedral cells? Actually I can give a part of the answer: there are the polyhedra but with some extra lines. What are those lines?
Dragos
Old   December 9, 2007, 02:42
Default What you were seeing in the pr
  #29
Takuya OSHIMA
What you were seeing in the previous post was the polyhedra decomposer in foamToVTK working perfectly
foamToVTK decomposes a polyhedron into tetrahedra and pyramids since currently VTK can't handle polyhedra perfctly as is (which is what the native reader for ParaView3 I posted a while ago also still suffers from).
Takuya
Old   April 27, 2008, 11:51
Default Matthijs, Eric, Bastil, I h
  #30
Mark Couwenberg
markc is on a distinguished road
I have exactly the same problem as Bastil described in december. I have a tet mesh which checkMesh says is ok, nil errors nor warnings.
Converting it using polyDualMesh, trying different aspect angles, gives warnings regarding edge orientations. The utility concludes its work anyway but than using checkMesh, the new mesh contains errors and warnings. The error I see returning everytime is wrongOrientedFaces. But also warnings regarding warpedFaces and concaveFaces return regularly. I tried this sequence with different models and within each model with different meshes. Note that I have no cellZones or faceZones.
So in short: checkMesh says my original tet mesh is perfect. Nevertheless polyDualMesh is not succesfull in converting it in a polyhedral mesh.
Tet meshes have been generated with gid and exported using unv format.
Why I all need this:
I am trying to model sailing ships using VOF interFoam. The water-air interface is of great interest to me as a ship designer.
In order to gain experience I played with the damBreak tutorial. I remodeled the geometry and generated the mesh with the tools I would like to use for the ship-problems as well. Also here I find the same problems, however I finally manage to make the solution run to an end with the polyhedral mesh. The tet mesh gives unstable solutions. To my knowledge I have tried all possible solver settings and scheme options:
-max Co, as low as 0.1
-cGamma, Gamma subcycles upto 4
-with and without momentumpredictors
-nCorrectors 1-4
-nonOrtho correctors, upto 10
-tolerances, upto E-9
-PCG and GAMG pressure solvers, different preconditioners, different U solvers.
and more.
Making the step to my ship models, I cant run any solution successful. After a few tenths of runtime seconds, some high velocity spikes appear, whatever I try.
I tried potentialFoam, which returns a velocityfield without unstabilities. However, the velocityfield does not seem very regularor smooth.
Velocity spikes appear mostly on boundaries, just above the water interface. On the model, different boundary conditions apply: pressureOutlet and symmetryplane. I also tried extrapolatedOutlet. All the same.
I suspect my mesh quality to be the showstopper, though I read a couple of threads where Henry states that, though hex meshes are preferred, even on tet meshes interFoam should work.
Other possible causes (hope someone can comment):
-my boat is 16 m long and sails at 5m/s. This gives Re of order e-6 in the air. Should I use turbulence models? I hope not, as I am only interested in the water.
Probably the best solution is to make hex meshes. However presently I have no tools at hand which can do this.
Concluding:
-Instability in VOF solution;
-Suspect mesh quality/mesh type (tet);
-Improper conversion of my (perfect?) tet mesh into polyhedral.
In fact the second half of my questions belong to another place of this forum. Apologize for that.
Any comments will be greatly appreciated,
Mark
markc is offline   Reply With Quote
Old   April 29, 2008, 17:25
Default Hello All, Any comments abo
  #31
Mark Couwenberg
Hello All,
Any comments about the polyDualMesh issue? (having a pure tet mesh which checkMesh says is perfect, which fails with polyDualMesh. Giving error about wrong edge orientation and checkmesh gives errors about face orientations).
Any help would be greatly appreciated.
Mark
Old   April 29, 2008, 17:46
Default In order for polyDualMesh to w
  #32
Hrvoje Jasak
In order for polyDualMesh to work, your tet mesh must be Dealuney. If it was made using marching front, it will probably fail.
Hrv
parthigcar likes this.
Hrvoje Jasak
Old   May 5, 2008, 04:36
Default Hi, I've also been having tr
  #33
Andrew King
andersking is on a distinguished road
I've also been having trouble with polyDualMesh and edge/face orientations.
Generally it always happens for at the edges of 'concave' patch boundaries.
the image below shows a simple case, with the incorrect faces highlighted (using checkMesh).
The mesh was generated with netgen using the delauney scheme. If the truncated corner is removed polyDualMesh works fine (ie a normal cube).
So far this has meant I haven't been able to use polyhedral meshes for anything useful (apart from making pictures of polyhedral meshes). Any advice would be greatly appreciated.
Cheers
Andrew
Dr Andrew King
Fluid Dynamics Research Group
Curtin University
andersking is offline   Reply With Quote
Old   May 9, 2008, 15:56
Default Hrv, Thanks for your reply. T
  #34
Mark Couwenberg
Hrv,
Thanks for your reply. The meshing tools I have available do not tell me Dealuney or marching front (?). However I assume that will be the root cause of the problem. I read on the forum that you state it WILL be possible to have stable solutions with interFoam and tet meshes. I am struggling now for weeks on some boat problem with a tet mesh. I am now able to run it quiet far but sooner or later some velocity spike appears, mainly just above the water-air interface, only on the boundaries. I have varied the boundary conditions. On the free patches they are p=0 and zerogradient for U and gamma. This must be ok.
Solvers I varied, with mostly only slight succes. Now I am more focussing on schemes. I found that upwind on div(rho*phi,U) was a huge improvement in stability. However after some longer time a velocity spike appeared again.
Now I am testing with limiters and linearUpwind. I will attach my current fvSchemes. Hopefully someone can comment on it.
I will also add some snapshots of my case.
fvSchemes
SnapshotU.pdf.tar.gz
Snapshotgamma.pdf.tar.gz
Thanks for any comments,
Mark
Old   May 11, 2008, 05:45
Default Update: I used gmsh to genera
  #35
Mark Couwenberg
Update:
I used gmsh to generate delauney meshes, nil errors/warnings with checkmesh. PolyDualMesh runs on these meshes but checkmesh than returns with errors as indicated by Andrew King.
Using the mesh anyway for solving gives unstable results very soon.
Besides that: I hoped that I could use refineMesh on these polyHedral meshes. However this introduces even more errors in the mesh. I thought that refineMesh shuold work on polyHedral. It does not in my case. All kinds of skew faces, wrong orientations, concave faces etc etc appear. Am I doing something wrong or is my mesh just one step too challenging?
Brgds,
Mark
Old   September 13, 2008, 18:50
Default Use of polyDualMesh on a 'good
  #36
Chris Sideroff
cnsidero is on a distinguished road
Use of polyDualMesh on a 'good' tet mesh (by checkMesh's standard) generates the same errors for me as Mark and Bastil.
Has anyone else encountered difficulties? Has anyone found any work around for this? Is this possibly a bug in polyDualMesh?
Chris
cnsidero is offline   Reply With Quote
Old   September 13, 2008, 18:56
Default Hi Chris, I have never had
  #37
Kevin Maki
kjmaki is on a distinguished road
Hi Chris,
I have never had reliable success with polyDualMesh, except for domains that have very simple boundary surfaces. (I was not surprised to see that Andrew King's case was ok with a single cube, but failed when the corner was truncated.)
I am not sure if this was a bug, or lack of functionality for the cases that are of interest to me.
Kevin
kjmaki is offline   Reply With Quote
Old   September 13, 2008, 21:58
Default Thanks for the reply Kevin.
  #38
Chris Sideroff
Including myself that's four people in this thread that seem to agree that polyDualMesh only works for simple cases.
I was interested in comparing the setup, run-times, memory usage and results of a tet mesh and it polyhedral dual. Perhaps I will try on something simpler than I have been testing with.
Old   September 14, 2008, 05:33
Default For the dual mesh to work, the
  #39
Hrvoje Jasak
For the dual mesh to work, the underlying tet mesh must be Dealuney. If this is so, the algorithm will work fine; otherwise it will fail.
It would be nice to have a check which would make sure that the tet mesh is actually Delauney before starting. Chris, do you happen to know a tool like this, or would we have to write it from scratch?
Hrv
Hrvoje Jasak
Old   September 15, 2008, 00:14
Default Hrv, I don't know of any 'D
  #40
Chris Sideroff
Hrv,
I don't know of any 'Delaunay checkers'. I believe the tet mesher in Gridgen/Pointwise is Delaunay based but I don't know how strict it maintains it.
With regard to my failure, I have to admit it is probably not the most appropriate mesh to try polyDualMesh with (~300 surfaces and ~2mi tets with cell sizes vary several orders of magnitude). I am going to try it on a more 'intermediate' type problem this week.
Chris
Polyhedral mesh generation sanathkeshav ANSA 1 September 3, 2018 10:39
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 07:21
[ICEM] Need urgent help for hybrid mesh generation Pursuor ANSYS Meshing & Geometry 1 August 29, 2012 17:04
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
