[Technical] How to identify cell neighbours
Like Tree30Likes
Old   December 12, 2010, 00:02
su_junwei's Avatar
su junwei
su_junwei is on a distinguished road
Send a message via MSN to su_junwei
Originally Posted by yashar.afarin View Post
Hi Su
how I could export my data so that I could specify and link for each point(cell centre) , the position(x,y,z) and velocity(u,v,w) variables of that point as a same file?
// include the head file
#include"OFstream.H"
//declare a object and out the variable you want. file.dat is the name of the //file you need.
OFstream os("file.dat");
forAll(mesh.C(), i)
os<<mesh.C()[i] <<" " <<u[i]<<endl;
songwukong and SH_Zhong like this.
su_junwei is offline   Reply With Quote
Old   January 17, 2011, 06:10
Yashar Afarin
yashar.afarin is on a distinguished road
Send a message via Skype™ to yashar.afarin
Hi SU
thank you very much for all of your helps.
I would appreciate if you could answer my question.
I have calculated Umean by introducing a function at system/controlDict of my case and I can see its contour with paraFoam.
how I could export it (UMean) to a .dat file, similar to my last question about U ?
yashar.afarin is offline   Reply With Quote
Old   January 17, 2011, 06:56
su_junwei's Avatar
su junwei
Hi SU
You don't have to process UMean. It should be in the time dir in your case.
Old   January 17, 2011, 08:02
Yashar Afarin
yes, it's there but I want to export it to a file.dat. according to your reply I export U of each point but I don't know how I could do that again for UMean?
I would appreciate if you could help me.
Old   January 17, 2011, 08:55
su_junwei's Avatar
su junwei
Just copy the internalField to a seperate file name *.dat
If you want to do it using a program, Just write a small tool for post processing. Read the file and write the internalField to a file
forAll(UMean.C(), i)
os<<mesh.C()[i] <<" " <<UMean[i]<<endl;
songwukong likes this.
Old   January 17, 2011, 09:35
Yashar Afarin
thank you very much for your reply.
I wrote the code that you sent for me in applications/solvers/incompressible/pisoFoam/pisoFoam.C
but when I compiled it, an error would be reported:
write.H:55: error: ‘UMean’ was not declared in this scope
I cant understand what is the problem, plz give me help!
Old   January 17, 2011, 11:43
Yashar Afarin
I am sorry. that was my silly reply. I know what you mean now. thanks for your reply.
Old   February 22, 2011, 15:53
Default problems with mesh.cellCells()
  #28
Rudi T.
daZigeiner is on a distinguished road
Hi Khaled
mesh.cellCells()[cellI] gives the neighbours of cell cellI
su junwei
Hi Su
I'm just working on a possibility to refine locally on a selection of the mesh (blockMesh with refinementIterator). Since I have higher refinement levels I need to lay some buffer-layers around the selection. For this purpose I use the cellCells() function in multiple iterations.
My problem is that cellCells() does not recognize all neighbours of already refined cells (The refinement history I have implemented works fine and has no bugs) .
I'll give a little example:
- 8 cells (= refinement level 3) on the west side of a simple refined cell (= 2 cells f.e. cell A and B).
- this should give cell A as eastern neighbour for four of the tripple refined cells and cell B for the other four cells
- instead of this cellCells returns only cell A as eastern neighbour for all eight cells!!
And now the really big problem:
This bug is not reproduceable, since the correct recognition of all neighbours works fine in the mesh of forwardStep (tutorials/compressible/rhoCentralFo...), but not in the mesh of counterFlow2D (tutorials/combustion/reactingFoam...)
daZigeiner is offline   Reply With Quote
Old   May 22, 2011, 21:22
maysmech's Avatar
maysmech is on a distinguished road
forAll(mesh.C(), i)
Hi Su,
Is it possible describe it more for me?
Where should be written this code and how should it be compiled?
maysmech is offline   Reply With Quote
Old   May 22, 2011, 23:38
su_junwei's Avatar
su junwei
just write it in the time cycle. os declaration can be written in creatFields. H
You can write it like the following code
if(runTime.outputTime()) //only write at outputTime point
forAll(mesh.C(), i)
Old   January 7, 2012, 19:24
Robin Gilbert
robingilbert is on a distinguished road
Originally Posted by kathrin_kissling View Post
Hi Pascal,
alternatively you can use
label labelOfClosestCell mesh.findCell(c y z);
Best Kathrin
Kathrin,
I am getting the following error when I use this:
transientSimpleFoam.C: In function ‘int main(int, char**)’:
transientSimpleFoam.C:123: error: expected initializer before ‘mesh’
transientSimpleFoam.C:124: error: ‘labelOfClosestCell’ was not declared in this scope
Any ideas why this is happening?
Thank you.
robingilbert is offline   Reply With Quote
Old   January 8, 2012, 13:08
Kathrin Kissling
kathrin_kissling is on a distinguished road
I think something is wrong with my formatting:
const point& location = (x,y,z); //your coordinates
label labelOfClosestCell=mesh.findCell(location);
Can you post your code?
Thanks!
Kathrin
kathrin_kissling is offline   Reply With Quote
Old   January 8, 2012, 16:52
Robin Gilbert
Kathrin,
Thanks for your reply. It was indeed the problem with the way I specified my location. I got it working.
Thank you.
Old   May 23, 2012, 08:18
Kim Yusik
impecca is on a distinguished road
Hi, Junwei
I am trying to access the neighbour cells with parallel computing but it seems the cell which is placed adjacent to the interface between sub-domains does not recognize all neighbour cells.
I followed the same as you mentioned which is briefly (I am using OF-2.1.x),
So I am wondering that you have a similar experience and is there any possible solution on this?
I also posted the question on this issue but I haven't got respose so far.
http://www.cfd-online.com/Forums/ope...computing.html
Thanks in advance.
Yusik
impecca is offline   Reply With Quote
Old   August 14, 2012, 11:56
Wei Liu
mathslw is on a distinguished road
Hi Pascal
you can use the following code
meshSearch ms(mesh);
label nearestCellIndex = ms.findNearestCell(p);
p is your point for searching nearest cell. nearestCellIndex is the cell index that you want.
Don't forget to include "meshSearch.H"
Junwei
Hi Junwei,
Could the p be a face in the internal field. If it could be, how can I define it?
Many thanks!
Wei
mathslw is offline   Reply With Quote
Old   October 2, 2012, 13:39
Default X, Y and Z of each cell
  #36
hawkeye321 is an unknown quantity at this point
hey, does anyone know how can I get the x, y and z of each cell?
hawkeye321 is offline   Reply With Quote
Old   September 23, 2013, 21:44
Wei Liu
Hi Junwei
As I see, the cellCells gives the list of index, my question is how could distinguish them?
thanks
Wei
Hi Khaled
su junwei
Old   September 25, 2013, 03:31
su_junwei's Avatar
su junwei
The return value is a list of index of neighbor cells. cells can be distinguished from another from cell index, cell center, etc.
Old   May 5, 2014, 16:38
CHARLES
CHARLES is on a distinguished road
I'm confused about how to access a specific cell using cellCells. For example, how can I use cellCells to access the NORTH cell of each cell in my domain?
Here's an example of what I would like to do... I know that the code may not compile, I'm just trying to explain what I'm doing.
V=value; //V is a boundary field ('value' is calculated and varies across the domain)
forAll(U, celli)
U[celli]=V[celli];
U[NORTH of celli] = U[celli];
CHARLES is offline   Reply With Quote
Old   December 19, 2014, 02:58
Bobby
babakflame is on a distinguished road
Hi Pascal
Junwei
Greeting Su
Is it possible to detail your hint more clearly?
I guess that the meshSearch.H should be added to the main code for instance reactingFoam.C . But what about
Where should I add these lines?
Thanks for your hints.
Best,
Bobi
babakflame is offline   Reply With Quote
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
Determining cell neighbours on unstructured grid orxan.shibli Main CFD Forum 4 September 25, 2011 06:29
Help Me, what's the Cell Above any given cell in 3D. gomane8 Main CFD Forum 3 September 11, 2011 22:29
neighbours of a cell Asghari FLUENT 17 October 7, 2010 18:41
neighbours of a cell Asghari FLUENT 0 July 9, 2006 14:28
