[Gmsh] Problem with Gmsh
Like Tree4Likes
Old   August 4, 2015, 08:03
Rafael Marques
rafa13 is on a distinguished road
Hi Kate,
I think that gmsh2ToFoam are not for above OF1.4.1. When i get this default faces problem mostly it is because of the definition of the physical surfaces that are not defined. I you get default faces in the interior of the mesh try to remove the mesh with topoSet, or simply go to constant/polymesh/boundry and look if there are 0 faces if so delete the hole boundry and change the number of the top left of the file, this number indicates how many boundry do you have. try it maybe it works
Kind regards
Rafa Marques
rafa13 is offline   Reply With Quote
Old   August 4, 2015, 11:42
KateEisenhower is on a distinguished road
Hi Rafael,
thanks for your opinion! Unfortunately there are more than 0 faces in it. However, I'll have a look at topoSet!
Best regards,
Kate
KateEisenhower is offline   Reply With Quote
Old   August 4, 2015, 23:12
Default Answer
  #23
tareqkh's Avatar
CFD
tareqkh is on a distinguished road
Hey Kate,
Could you be more specific by sharing your case?
Best,
tareqkh is offline   Reply With Quote
Old   August 5, 2015, 03:09
Dear Tareqkh,
unfortunately I am not allowed to share this stuff. I'll try to describe it however. I have a part of a wing which I want to mesh with a boundary layer all around it. At the trailing edge gmsh has serious problems to create a decent mesh. I keep getting lots of non manifold faces, wrong oriented faces and so on. My default faces are located in the same area and I am quite sure this is related to the overall bad quality of the mesh at this location.
So my primary objective is to solve this problems and I hope the default face are going to disappear after that anyways.
If I wouldn't work with an imported stl geometry, I'm sure I could solve this by using transfinite entities around the trailing edge but somehow I have trouble combining them with my imported and extruded stl geometry.
Best regards,
Kate
Problem diverges when exhaust valve opens swerner0711 AVL FIRE 0 September 21, 2018 08:14
[Gmsh] gmsh meshing problem CHAYANIT OpenFOAM Meshing & Mesh Conversion 0 September 5, 2018 09:08
Gmsh problem liub Mesh Generation & Pre-Processing 0 December 17, 2015 14:26
[Gmsh] gmsh problem djamel OpenFOAM Meshing & Mesh Conversion 0 January 7, 2014 14:02
[Gmsh] Ubuntu 12.10 Gmsh installation problem sudo OpenFOAM Meshing & Mesh Conversion 0 November 7, 2013 13:47
