[Gmsh] Create Hex Mesh
Old   November 3, 2008, 11:37
Default Create Hex Mesh
fabrizio
fabrizio is on a distinguished road
Hi dear users, I'm an engineer student in Milan, Italy. I use Calculix to build Fem analysis importing OpenFoam results. To complete this import I need a hex mesh; how can I create a hex mesh with Gmsh? I've read a lot of tutorial, but are all concerning Gmsh generation of tet mesh.
Can you help me?
King regards
Fabrizio
fabrizio is offline   Reply With Quote
Old   November 3, 2008, 14:30
Default Hello Fabrizio, As far as I
Philippose Rajan
philippose will become famous soon enough
Hello Fabrizio,
As far as I am aware, Gmsh cannot create a Hex mesh of a complex 3D geometry.
For most practical cases I have come across, Gmsh (and all other open source meshing software I have tried) only generates pure tetrahedral meshes.
Philippose
philippose is offline   Reply With Quote
Old   November 3, 2008, 16:33
Default Hi thank you for your reply. M
fabrizio
Hi thank you for your reply. My geometry is quite simple. Can you tell me how use gmsh to generate the mesh?
Thank you
Fabrizio
Old   November 3, 2008, 17:18
Default Hello again, Well.... I cou
Philippose Rajan
Hello again,
Well.... I could probably help you out if I got to see the geometry :-)! As in... for example...
1. What format is your geometry in?
2. Have you been able to load it into GMSH yet?
3. What format do you want the output in... and does GMSH support this format?
4. How does the geometry itself look?
5. etc...etc...
Quoting from the GMSH Website:
"Gmsh's mesh module regroups several 1D, 2D and 3D mesh algorithms, all producing grids conforming in the sense of finite elements (see section 1.2 Mesh: finite element mesh generation).
The 2D unstructured algorithms generate triangles or both triangles and quadrangles (when Recombine Surface is used: see 4.2.3 Miscellaneous). The 3D unstructured algorithms only generate tetrahedra.
The 2D structured algorithms (transfinite and extrusion) generate triangles by default, but quadrangles can be obtained by using the Recombine commands (see 4.2.2 Structured grids, and 4.2.3 Miscellaneous). The 3D structured algorithms generate tetrahedra, hexahedra, prisms and pyramids, depending on the type of the surface meshes they are based on. "
So, if you need to create unstructured 3D meshes, then tetrahedral meshes are the only option....
Hope this helps..
Philippose
Old   November 5, 2008, 11:30
Default Hi Philippose thank for help.
fabrizio
Hi Philippose thank for help. I've decided to try another way to mesh my model, I think that SnappyHexMesh utility could be great for my pourpose.
Thank you again
Fabrizio
Old   November 9, 2008, 13:17
Default Hi fabrizio, I'm aso a enginee
Marco Moscaritolo
mavimo is on a distinguished road
Hi fabrizio, I'm aso a engineer student in Milan
For snappyHexMesh I'm writing tutorial, you can find first step on http://www.cfditalia.org [IT].
If you have sono question or can help me to write it please contact me
mavimo is offline   Reply With Quote
Old   November 9, 2008, 14:20
Default Hi Marco thanks for your reply
fabrizio
Hi Marco thanks for your reply. I have some problems in writing the snappyHexMeshDict file, the OF tutorial about this topic is not very clear in my opinion. I've read the tutorial in the site you suggested, but it's not about snappyHexMeshDict file, I've alredy created the base mesh with blockMesh utility; I'll be very interested in the second part of the tutorial when it will be on line. If you want we can meet in university, so we can speak about our OF works.
Thank you again
Fabrizio
Old   November 10, 2008, 14:59
Default hi fabrizio, contact me by mai
Marco Moscaritolo
hi fabrizio, contact me by mail (find it on my profile)
Old   November 12, 2008, 12:48
Default dear all, i have the problem
erik023
dear all,
i have the problem of getting very poor results when using a finer (0.1-0.3 m) background (blockmesh) for snappy. it does not seem to perform the refine surface. i get muche better results for the surface when using a very coarse background mesh (0.5-1m)
why is it behaving this way, there is now error when i run checkmesh?
thanks erik
Old   March 22, 2010, 10:09
Claus Meister
idrama is on a distinguished road
Ciao mavimo,
I tried to reach your page which did you announced. But i could not get on it. Is it down? However, proparly you are very involved into snappyhexmesh. Therefore , I want to ask you the question how to avoid polyheder. Because I need a mesh consisting purely of hexhedron. How can I make it happen?
Cheers
idrama is offline   Reply With Quote
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! divergence OpenFOAM Meshing & Mesh Conversion 0 January 23, 2019 05:17
[blockMesh] BlockMesh number internal faces and boundary ynos OpenFOAM Meshing & Mesh Conversion 6 December 13, 2011 06:36
[blockMesh] Blockmesh error - 2D scramjet ishaninair OpenFOAM Meshing & Mesh Conversion 7 March 18, 2011 01:14
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 02:07
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
