[blockMesh] Trouble with mergePatchPairs
Old   March 21, 2006, 12:11
Default Trouble with mergePatchPairs
Julien FAURE-BONDAT
debris is on a distinguished road
I'm trying to mesh a "disc" with the "butterfly" method. I've done 4 patches for each quarter of the ciruclar geometry, and 8 patches for faces to merge (in blockMeshDict).
When I don't write anything in mergePatchPairs, I don't get any error message. But when I write patches to merge in mergePatchPairs (in blockMeshDict), I get this strange error message :
--> FOAM FATAL ERROR : Face 3735 reduced to less than 3 points. Topological/cutting error B.
Old face: 2(626 624) new face: 2(626 624)
From function void slidingInterface::coupleInterface(polyTopoChange& ref) const
in file slidingInterface/coupleSlidingInterface.C at line 1680.
FOAM aborting
I don't know why I get this message because my mesh seems to be correct. When I run it into paraview, I don't see any block problems, and faces to merge are exactly at the same place.
I'm pretty trapped with this problem, I hope you could help me. Thanks for your answers ^^.
debris is offline   Reply With Quote
Old   March 22, 2006, 11:32
Default Hi Julien, I meshed (the ins
Rasmus Hemph
hemph is on a distinguished road
Hi Julien,
I meshed (the inside of) a pipe not to long ago. If you want, I can send you the file I used. No sliding interfaces or merging of patch pairs in my case though!
//rasmus
hemph is offline   Reply With Quote
Old   March 22, 2006, 12:47
Default Hi Rasmus, Did you use a "b
Julien FAURE-BONDAT
Hi Rasmus,
Did you use a "butterfly" method to mesh your pipe or did you simply mesh it with arc or spline edges ?
Even if you didn't have mesh your pipe with a "butterfly" method, the file you used could perhaps help me. It would be cool if you can send it to me ^^. I'm new on this forum, but I think you can send me the file on my email adress in my profile.
Thanks.
Julien.
Old   March 23, 2006, 04:29
Default Here is a picture of the mesh.
Rasmus Hemph
Here is a picture of the mesh. The script I used to generate it is attached. It was done using the preprocessor m4 (search the wiki for more info). You change the radius, length and wanted number of cells in pipeMesh.m4 and generate your blockMeshDict as:
m4 pipeMesh.m4 > blockMeshDict
Then you run blockMesh on the file as usual. Hope it helps!
pipemesh.m4
Old   March 23, 2006, 10:51
Default I've tried your mesh and it wo
Julien FAURE-BONDAT
I've tried your mesh and it works correctly (nice little script btw). You've done your mesh with arc edges, but I can't do my mesh with the same method, because my blockMeshDict file is written from a points file realized by another mesh soft. I have to merge some of the patchs
Here is a picture of my mesh, my mesh sounds good but merging patches doesn't work and I get boundary inside my pipe...
My blockMeshDict is attached.
Thanks for your help. I'll maybe try to mesh my points file with another method (like yours) if I can't figure out how to merge theses 8 patches.
[IMG]http://img139.imageshack.us/img139/1359/tube0nk.jpg[/IMG]
Old   March 23, 2006, 11:05
Default Sorry, I forgot the blocMeshDi
Julien FAURE-BONDAT
Sorry, I forgot the blocMeshDict file...
points.zip
Old   March 23, 2006, 11:18
Default The second part of the blockMe
Julien FAURE-BONDAT
The second part of the blockMeshDict. I'm not really used to use this kind of forum ;-). (I can't edit my posts, sorry for triple post).
blocks_patches.zip
Old   April 3, 2006, 11:57
Default Ok, I've fixed my problem. I'v
Julien FAURE-BONDAT
Ok, I've fixed my problem. I've created a double line where I needed to merge some patches in order to merge my patches from a external patch to another one.
Thanks for your help Rasmus btw.
[blockMesh] mergePatchPairs problem when migrating from OFext1.6 to OFext3.1 ma-tri-x OpenFOAM Meshing & Mesh Conversion 2 January 12, 2021 05:23
[blockMesh] mergePatchPairs reducing a face to less than 3 points aow OpenFOAM Meshing & Mesh Conversion 2 June 1, 2018 18:37
[mesh manipulation] mergePatchPairs with multiple areas bjoern1 OpenFOAM Meshing & Mesh Conversion 1 October 1, 2015 08:07
[blockMesh] Trouble with MergePatchPairs: Duplicate Point Found in Cut Face dancfd OpenFOAM Meshing & Mesh Conversion 4 March 13, 2014 04:01
[blockMesh] mergePatchPairs Misbehaving dancfd OpenFOAM Meshing & Mesh Conversion 2 July 20, 2011 01:08
