[blockMesh] BlockMesh for a rectangular domain with curved bottom surface
Old   April 17, 2006, 15:11
Default BlockMesh for a rectangular domain with curved bottom surface
David Segersson
segersson is on a distinguished road
I looking for a way to generate a 3d hexahedral or prismatic mesh for a rectangular domain with a curved bottom surface (topography). The mesh should be graded in the vertical direction. It is not important if the mesh is structured or unstructured.
Does anybody know if it is possible to do this using blockMesh, the openFoam mesh utilities, the stlToGmsh utility posted on this site or some other free meshing code?
I think I can find a way to construct the bottom surface mesh. If I'm not mistaken, what is left is to extrude the mesh upwards, and at the same time smooth away the curvature of the bottom surface to give me a flat upper boundary. This does not sound to difficult (I hope I'm not mistaken...). If I would try to write such a utility myself, does anyone have any advice on what to think about.
Regards
David
segersson is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh castellation stage creates hole in surface where mesh flows into domain Dav3dum OpenFOAM Meshing & Mesh Conversion 0 August 30, 2017 05:19
How to make a curved surface with a hole in it by using structured domain? ian0103 Pointwise & Gridgen 7 May 26, 2016 00:25
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
[blockMesh] Flow domain by BLOCKMESH for plasma induced flow simulation mukut OpenFOAM Meshing & Mesh Conversion 0 June 2, 2014 07:19
[ICEM] Meshing cylinder with curved bottom surface and cylindricla sparger in it oj.bulmer ANSYS Meshing & Geometry 3 April 18, 2012 11:58
