November 29, 2006, 21:22 |
Cylinder mesh help to fix it
Hi, my mesh doesn't work. Does anyone knows why?
Is a cylinder top and botton walls heated and adiabatic walls. A error message "--> FOAM FATAL ERROR : Trying to specify a boundary face 4(8 12 13 9) on the face on cell 3 which is either an internal face or already belongs to some other patch. This is face 2 of patch 0 named floor." is showed the body is: convertToMeters 1; vertices ( (4 0 4) //0 (14 0 4) //1 (14 5 4) //2 (4 5 4) //3 (4.0707 0 4.0707) //4 (13.9293 0 4.0707) //5 (13.9293 5 4.0707) //6 (4.0707 5 4.0707) //7 (4.0707 0 13.9293) //8 (13.9293 0 13.9293) //9 (13.9293 5 13.9293) //10 (4.0707 5 13.9293) //11 (4 0 14) //12 4 (14 0 14) //13 5 (14 5 14) //14 6 (4 5 14) //15 7 ); blocks ( hex (4 5 6 7 8 9 10 11) (3 3 10) simpleGrading (1 1 1) hex (0 1 2 3 4 5 6 7) (3 3 10) simpleGrading (1 1 1) hex (1 13 14 2 5 9 10 6) (3 3 10) simpleGrading (1 1 1) hex (13 12 15 14 9 8 11 10) (3 3 10) simpleGrading (1 1 1) hex (0 3 15 12 4 7 11 8) (3 3 10) simpleGrading (1 1 1) hex (12 15 14 13 8 11 10 9) (3 3 10) simpleGrading (1 1 1) ); edges ( /* arc 0 1 (16.0711 0 9) arc 1 13 (9 0 16.0711) arc 13 12 (1.9289 0 9) arc 12 0 (9 0 1.9289) arc 3 2 (16.0711 5 9) arc 2 14 (9 5 16.0711) arc 14 15 (1.9289 5 9) arc 15 3 (9 5 1.9289)*/ ); patches ( patch floor ( (4 8 9 5) (1 5 9 13) (8 12 13 9) (4 0 12 8) (0 4 5 1) ) patch ceiling ( (7 6 10 11) (6 2 14 10) (10 14 15 11) (3 7 11 15) (2 6 7 3) ) wall fixedWalls ( (2 3 0 1) (14 2 1 13) (15 14 13 12) (3 15 12 0) ) ); mergePatchPairs ( ); what's wrong? thanks! |
December 3, 2006, 09:38 |
my problem was solved.
December 6, 2010, 11:44 |
Rep Power: 17 |
hi, how did you solved it?
thanks |
Prescribed Translating Cylinder Mesh for Added Mass Problem (Transient FSI) | Lloyd Sullivan | CFX | 5 | August 7, 2018 09:11 |
[ANSYS Meshing] Fluent: 2-way FSI. Mesh around moving cylinder | asking | ANSYS Meshing & Geometry | 1 | May 25, 2018 13:04 |
[blockMesh] Cylinder mesh using blockMesh with m4 macro | Lewis Liang | OpenFOAM Meshing & Mesh Conversion | 2 | November 21, 2017 03:28 |
[ICEM] Meshing inclined cylinder with PBC tetra mesh ICEM | shashi_soman | ANSYS Meshing & Geometry | 0 | September 26, 2015 19:27 |
rotating cylinder using sliding mesh | Tim Daly | FLUENT | 1 | November 10, 2008 00:02 |
