[blockMesh] Mesh generation for wedge shaped blocks
Old   December 19, 2007, 20:43
Default Mesh generation for wedge shaped blocks
Trinia Dzurny
tdzurny is on a distinguished road
I'm trying to modify a model for flow around a 180 degree bend by collapsing the corner blocks into a wedge shape, so that they have a 45 degree angle rather than a 90 degree angle. I'm having trouble with the generated mesh and was hoping someone could help. The link below shows the mesh.
www.hydrocalc2000.com/images/corner_mesh.jpg
As you can see from the image, the corners are successfully collapsed, but the mesh is collapsed as well, resulting in a cell distribution that isn't smooth. I'd like for the gridlines to follow the same straight lines as in the uncollapsed blocks. The cells on the collapsed edge would be wedges, in that case.
Any ideas on how to do this? Thanks
tdzurny is offline   Reply With Quote
State of mesh generation Wandadars Main CFD Forum 3 January 5, 2017 13:51
New Mesh Generation and Pre-Processing Forums pete Site News & Announcements 2 December 26, 2012 18:56
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
3-d elliptic generation mesh Gang Sun Main CFD Forum 5 September 16, 1998 01:24
