[blockMesh] RefineMesh warning
Old   August 25, 2008, 04:47
Default RefineMesh warning
mayank gupta
mgz1985 is on a distinguished road
I m trying to validate the coeffiecients of forces for an airfoil but I am getting wrong values for Cl from the wind tunnel compared to the wind-tunnel results.
Everything is correct and fine. Except when i execute refineMesh I get this error.
--> FOAM Warning :
From function forces::forces(const objectRegistry& obr, const dictionary& dict)
in file forces/forces.C at line 164
No fvMesh available, deactivating.
Can some one help regarding this? I am attaching my blockMeshDict with this message
blockMeshDict
mgz1985 is offline   Reply With Quote
Old   August 29, 2008, 09:45
Default This is a Warning, not an erro
Eugene de Villiers
eugene is on a distinguished road
This is a Warning, not an error. At the point where your forces object is initialized, there is no fvMesh available. It will become active again when you run an application which has a fvMesh in memory. (refineMesh only has a polyMesh not a fvMesh)
Basically, ignore the warning.
eugene is offline   Reply With Quote
Caffa 3D code Waliur Rahman Main CFD Forum 0 May 29, 2018 01:53
[swak4Foam] installation problem with version 0.2.3 Claudio87 OpenFOAM Community Contributions 9 May 8, 2013 11:20
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 05:37
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 07:59
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
